12-12-2018, 03:38 PM | #2 |
497
Rep 537
Well, that is almost a sentence... Give us some more information. Are you using the BimmerCode app? If so, what function did you enable and which module did you code? The more you share, the easier it is to help you.
'14 F30 328i M Sport // FBO // bm3 Stage 2+ DME Tune // Stage 1 TCU Tune // Apex EC-7s on Conti DWS06+s // 1 of 6 ever made of this spec (3C13 US-SULEV German-built //
12-13-2018, 06:49 AM | #3 | |
Rep 24
sport+ with vgate pro
I have bean trying to get the sport+ active with no luck went into bimmer app went to 3000 applikation and activate sportlenkung and sportschalter-alt and put them activ nothing I saw in my dash S1 my car is a 328i 2012 modernline please help me |
12-13-2018, 07:19 AM | #4 | ||
2465
Rep 5,457
Drives: F30
Sport+ can be coded completely in Simple mode now... Make sure you change the settings in two places... 1. Transmission Control Unit (TCU) 2. |
N26Ghost496.50 |
12-13-2018, 09:07 AM | #5 | |||
Rep 24
traction
12-13-2018, 09:13 AM | #6 | ||||
Rep 24
help
12-13-2018, 12:51 PM | #7 |
497
Rep 537
Try what sspade said using the simple mode.
If that doesn't work, restore your TCU to the backup and try this next: (Dutch) Als dat niet werkt, herstelt u uw TCU naar de back-up en probeert u het volgende: Sport+ mode ICM/3000 ICMKOD_B_SPORTLENKUNG nicht_aktiv ===> aktiv KOMBI/3000 FDS_MENUE_TEXT_1/2/3/4 menue_4 ===> menue_3 KOMBI/3000 FDS_MENUE_SIGNAL_1/2/3/4 menue_4 ===> menue_3 Make sure you change the values for all 4 menus (Zorg ervoor dat u de waarden voor alle 4 menu's wijzigt) Sport Automatic Transmission EGS/3000 Applikation -> Sportschalter_alt -> aktiv EGS/3000 Applikation -> Sportschalter -> aktiv EGS/3000 Applikation -> LC -> aktiv Included Dutch in case it helps.
12-14-2018, 11:46 AM | #8 | |
Rep 24
Hi Ghost
went into transmission control unit then went into instrument cluster to change values sory I'm little confuse where do i have to go in menu in order tu activate sport+ my car 2012 modernline 328i engine N20 |
12-19-2018, 11:18 AM | #9 | |
Rep 24
sport plus coding
ICM > 3000 > ICMKOD_B_SPORTLENKUNG = verbaut These are the only two codes that I could'nt find on my vgate I'm able to see the sport+ text coming up in my dash but no access to it can't select it the other menues I have change them from 1 to 4 to menue 3 and I happy cause I can see finally that I'm walking in the right direction so where can I find these two other settings to change there values all this I did it in expertmode we are almost done help |
