Radio Works but no sound.
12-12-2018, 11:15 AM | #1 |
25
Rep 61
Previous owner said he updated i believe he said CIC Hard drive? radio and all functions work. but no sound is coming from speakers and a SOS Light with a cross appears on the dash. He told me that it needs to be programed via INPA?
Thanks in advance D.
Current Rides
07 E92 335i 6-Speed SpeedTech Single Turbo Gen2 6266 22 Mercedes Benz GLB 250 4Matic |
12-12-2018, 12:18 PM | #2 |
1911
Rep 13,104
Could be also could be broken stuff on the Most Bus or a bad or
drowned Logic 7 amp. Unless someone changed and item such as the Head unit , a Most Bus Module or the Amp there would be no reason to suspect programing issues. Inpa is a diagnostic program NCSexpert is used for coding Winkfp is used for updating modules CIC is a complicated unit I would start by trying to see if its setup for the sound system in your car. There is a service mode that you can use to verify things like which sound system it's set up for an the rev levels. http://www.e90post.com/forums/attach...2&d=1260829447 Also check for water on the amp to get that out of the way. Last edited by ctuna; 12-12-2018 at 12:34 PM.. |
12-12-2018, 01:12 PM | #3 |
319
Rep 378
Had a no sound issue turned out that my satellite unit crapped out. Due to the fact the set up is a three component loop; I had to by pass the satellite unit to complete the loop and all returned to normal. I was not using satellite radio so no harm no foul, could have just as easily replaced unit if I wanted to.
