12-09-2018, 11:00 PM | #1 |
41
Rep 91
Battery registration question
I have the (paid) Bimmerlink app, and I use a VeePeak OBD2 adapter to use it. Earlier today, I installed a new battery in my car, and I tried to use the app to register it. However, I repeatedly got an error message saying that the battery registration failed. The battery I bought is not identical to the OEM battery that I took out. It says it’s 95amp vs (I believe) 90amp for the OEM battery. They are both 900 CCA. Is there any way to make Bimmerlink work, or should I look for a different solution? I have sent the same question to the developer (no answer yet), but thought I'd run it by this group as well to see what answers I get.
(2015 F33 N55) Thanks, Jeff |
12-10-2018, 12:11 AM | #2 |
2025
Rep 2,805
Drives: F33 430 and F39 M35i
I thought bimmerlink would only do it if the new battery was exactly the same as the old battery?
12-10-2018, 03:19 AM | #3 |
2465
Rep 5,457
Drives: F30
12-10-2018, 08:15 AM | #4 |
Respect My Authoritah
368
Rep 873
How come you're not replacing with whats in the car?
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
12-10-2018, 08:49 AM | #5 |
2025
Rep 2,805
Ok I remembered it sort of incorrectly. Here’s the post about it.
xxxjecxxx2 09:57 AM 09-19-2018 If you are replacing with same model battery, only registration is required. If you are placing battery that has difference amp hour rating or reserve capacity. The car needs to be programmed for the new capacity (example 90AH) THEN it needs to be registered |
12-10-2018, 09:11 AM | #6 | ||
4488
Rep 10,473
BMW does not offer a 90ah AGM battery any longer. It’s now a 92ah AGM battery and it’s half the cost. The aftermarket AGM batteries that most would use if not OEM are also 92ah. |
12-10-2018, 10:13 AM | #7 |
41
Rep 91
I bought a battery from an auto parts store that is a match for the vehicle. The one I purchased is actually slightly better (?) than the OEM battery. I assume 95ah is better than 90ah, but I don't really know the practical difference. The main reasons were cost and convenience. I paid $189 from a place by my house and put it in myself (vs $460 at the dealer, which would require an appointment, etc). I just have to figure out how to get the registration done. I heard back from Bimmerlink, and he asked me to send him the error log. I'll post when I hear back on that.
I have a local indy shop looking at an oil leak today (most likely the OFHG), and I asked them if they can register the battery while they have it. They're not a Euro-specific shop, though, so they're going to let me know if they can do it. --Jeff |
sspade2464.50 |
12-10-2018, 11:21 AM | #8 |
245
Rep 2,387
You need a better scanner with more capabilities. Carly allows you to input different specs for a new battery. Or look at the foxwell nt510.
2016 340i XDrive, EBII/black, 6 MT, M Sport, Track Handling, Cold Weather, Tech, Lighting, Driver Assistance Plus.
2012 Z4 35i, ED 2/24/2012, Melbourne Red Metallic, Black Leather, Carbon Trim, 6MT, M Sport, CW, PP, PS, NAV, CA. |
12-10-2018, 09:08 PM | #10 |
2963
Rep 5,997
Is there an official way to do this? We should have a right to repair our own vehicles without fear of voiding warranty from using third party coding tools.
12-10-2018, 09:16 PM | #11 | |
39
Rep 123
You would need ISTA/P to code a new type / new rating. Although 90ah-92ah seem close enough that you can just register as the same one no? Last edited by dvaz; 12-11-2018 at 12:58 AM.. |
jsouth112.00 |
12-11-2018, 10:14 AM | #12 | |
99
Rep 148
There isn’t a separate coding for 92Ah. The same E-word, A090, is used for both 90Ah and 92Ah AGM batteries. |
12-11-2018, 11:32 AM | #13 |
8243
Rep 16,082
10-03-2019, 01:37 PM | #14 |
76
Rep 233
How did your batt change/registration turn out. I'll be going through this soon and have BimmerLink to register it. Haven't purchased batt yet. Sent you pm that reads the same.
2015 Mineral White 335xi Sport trim
12-02-2019, 09:12 AM | #15 |
Rep 2
Has anyone actually used Bimmerlink to register a new battery yet? I see lots of talk "That it can" but I've yet to run across any post that states they've actually done it. I'm ready to replace my 2015 328i battery and have the bimmerlink soft and reader. Dealer wants $469 to do it.
12-02-2019, 09:24 AM | #16 |
41
Rep 91
I wasn't able to get Bimmerlink to register my battery, but I did end up buying Carly also, which appears to have that capability. I haven't used either of them for several months, however, so I don't know what the current capability is for either of them.
jj |
12-02-2019, 09:53 AM | #17 |
8243
Rep 16,082
For around $100 less than your stealer wants you can buy a battery and a Schwaben scan tool that will register your battery and a whole lot more.
https://www.ecstuning.com/b-schwaben...020sch01a~scf/ |
12-02-2019, 12:25 PM | #18 | |
806
Rep 1,906
12-02-2019, 12:32 PM | #19 | ||
2963
Rep 5,997
12-17-2019, 10:36 AM | #21 |
Rep 4
Error registering battery with BimmerLink
I am hoping for some help as I am experiencing the same error message when trying to use BimmerLink to register my 2011 E93's new Advance Auto 95Ah AGM battery that replaced the BMW AGM 92Ah AGM battery installed six years ago. I have attached a screenpic of the error below.
All the error codes have been cleared, so that's not actually the problem. And following BimmerLink support's advice I spent another 15 minutes this morning getting to and disconnecting/reconnecting the battery but that didn't help any. I have also tried restarting the car and app having ComfortAccess key in the slot or not. It's been roughly 10 days of not far driving on the new battery in an unregistered state. BimmerLink support has been timely but is out of suggestions. I can get a refund and order a more expensive Foxwell NT520, but BimmerLink support believes I will run into the same registration challenge. What advice does anyone have? I'm more than a little frustrated and tired of spinning wheels on an effort where getting the battery in place in the tight convertible slot should have been the biggest challenge! Thanks in advance, Trevor in Austin |
