12-08-2018, 11:10 PM | #1 |
10
Rep 18
Now I've seen everything
Just when I thought it was funny that the back end of our ML350 looked like a space shuttle wiring harness nightmare, I read that on my '15 328i the battery, if changed out, has to be registered to the cars system so the computer knows how much amperage the alternator needs to produce and other such crap. When will it ever end. I'm about ready for a 1976 American anything that I only need a screwdriver and an adjustable wrench to repair, and maybe some duct tape
12-09-2018, 06:34 AM | #3 |
981
Rep 1,560
Its not very smart unless it can easily be told (or recognize) a new battery has been installed.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
X2 Monstah301.00 Breezin20.00 |
12-09-2018, 07:13 AM | #4 | |
806
Rep 1,906
Local auto parts retailer installed new AGM battery in my 2012 X3- $210 out the door, no addl cost for coding/registration. Work completed in 30 minutes while I waited. Compare that with your local BMW Stealer's offerings😉 |
12-09-2018, 07:41 AM | #5 | ||
2465
Rep 5,457
Drives: F30
What did they use to code new battery? What battery did you choose? Im planning to use BimmerLink but wondering what an auto parts store would use. |
12-09-2018, 07:51 AM | #6 | |||
806
Rep 1,906
Battery is a 5 year warranty First Interstate- original BMW branded battery pulled from car was traditional lead acid type. I DIY many things but this was a very fair price and good service experience. I don't generally frequent places such as Pep Boys but this worked out quite well- The manager at this 2nd store told me the other store has the diagnostic gear but nobody there is trained to use it! |
sspade2464.50 |
12-09-2018, 08:16 AM | #7 |
8243
Rep 16,082
If you have a car that's old enough to need a battery and you do any of your own work you must have an OBD diagnostic tool. Not a reader, a tool, like the Foxwell NT510 With one you can identify fault codes, and just as important clear them and do other chores, like battery registration. Without one either be prepared to pay someone else to do all of the work on your car or get rid of the BMW and get something more user friendly, like a '57 Chevy.
12-09-2018, 09:46 AM | #9 | |
772
Rep 1,502
IK6SPEED4488.00 |
12-09-2018, 09:55 AM | #10 |
2025
Rep 2,805
Drives: F33 430 and F39 M35i
This battery registration thing has been around forever and a day. Do people not research cars anymore before buying?
12-09-2018, 12:39 PM | #11 |
98
Rep 227
Drives: 2000 BMW E39 M5
12-09-2018, 01:30 PM | #12 |
76
Rep 233
I'm going to find out what battery registering is! Is it like a formal introduction or a religious ceremony???
I own BimmerLink and was wondering what that was all about. What happens if you just drop in a new batt and ignore registration?
2015 Mineral White 335xi Sport trim
12-09-2018, 03:50 PM | #13 | |
806
Rep 1,906
From what I've read if you don't register the system may overcharge the new battery a bit- which may shorten its overall lifespan. Believe that's as bad as it gets-others here may know more in the topic. Good luck/Bill |
12-09-2018, 03:57 PM | #14 |
8243
Rep 16,082
The ability of a battery to hold charge goes down with age. To compensate for that the car increases the charge as the battery ages. If a new battery is not registered the car will continue to supply charge as if it was an old battery, so the battery may overcharge and could even be damaged. Worst case the car electrical system could be damaged. This probably wouldn't be a problem for a week or two, depending how much you drive, but it eventually would be a problem.
12-09-2018, 07:51 PM | #15 |
Cheapskate
4450
Rep 4,993
It's more efficient to have the computer regulate alternator amperage instead of the usual integrated regulator. Especially as more and more load is put on the electrical system. BMW was just one of the first to implement it.
12-09-2018, 08:06 PM | #16 |
poopycat
266
Rep 791
I haven't done this on a bmw yet, but typically you have a battery part number, vendor and serial number that is input. Tells the electronic battery regulation that a new cow is in town.
Many manu's do this, and it's really nothing new. |
12-09-2018, 08:16 PM | #17 |
2465
Rep 5,457
Drives: F30
Has anyone successfully registered a new battery with BimmerCode?
I know this is a feature and plan to use it someday when my original battery shits the bed. Just wondering if anyone has tried it yet and how they found the process. |
12-09-2018, 08:22 PM | #18 |
poopycat
266
Rep 791
Nope, just make sure your new battery has the 3 things I mentioned. Off the record, if it's similar, I have heard you can just increment the serial +1 (vw/audi/porsche world, so ymmv)
12-09-2018, 09:21 PM | #19 | |
66
Rep 204
Drives: 2016 428i GC Alpine White
From what I have researched, it's only complicated if you change the battery characteristics. If you simply replace the battery with an identical replacement, then it should be simple.
2016 428i GC
