12-06-2018, 07:37 PM | #1 |
102
Rep 353
G20 Series Price Affect on F3x?
I'll be looking into buying my first F3x 335i around the time that the new generation G20 comes out. Quite excited and hoping the F3x generation depreciates a bit so it'll be easier on the wallet
How much, if it all, do you guys expect the F3x M-sport models under 50k miles to depreciate once the new model releases? For CPO and non CPO Last edited by ktrvn; 12-06-2018 at 09:46 PM.. |
12-07-2018, 08:34 AM | #3 |
Guy with a car
98
Rep 224
Even though the G series is coming out, the market won't be effected a ton. You will most likely see a 10% or less drop since the F30 chassis is already at a cheap price. You will see a larger drop in LCI models then you will with the pre LCI ones.
15' 435i BSM on CR // BM3 Stage 2 93 OTS // NGK Plugs Gapped 0.023" // VRSF Catless DP // CTS Turbo Intake, CP, FMIC // AWE Tuning w/ Perf. Midpipe // BC Racing BR Coilovers // Apex EC-7 // Michelin PS4S // Plus a shit load of carbon
ktrvn102.00 |
12-07-2018, 09:12 AM | #4 | |
102
Rep 353
Just to make sure, the LCI models are 2015+ right? |
12-07-2018, 02:32 PM | #5 |
Guy with a car
98
Rep 224
Correct
12-07-2018, 02:37 PM | #6 |
102
Rep 353
12-07-2018, 02:50 PM | #7 |
398
Rep 102
12-07-2018, 02:53 PM | #8 |
102
Rep 353
Thank you Is there any real plus of getting LCI > pre LCI other then headlight/taillight difference? Factor out the EWG and PWG bc i plan on getting a 2014+ atleast which are EWG
Edit: Are the LCI models the 340i's? Or are there LCI 335i's? |
12-07-2018, 02:57 PM | #9 |
279
Rep 689
why would there be a larger drop on LCI models as compared to the pre-LCI? Are the Pre-LCI worth more the the LCI? Shouldn't it be there other way around? LCI is worth more the pre-lci. generally
12-07-2018, 03:50 PM | #10 | |
398
Rep 102
12-07-2018, 03:58 PM | #11 |
102
Rep 353
What would the suspension adjustments be? I found a thread containing info about the LCI F30 but it mainly talked about the cosmetics.
12-07-2018, 04:01 PM | #12 |
102
Rep 353
LCI's are generally worth more than the pre LCI. The way I understood his message is since the LCI is the model right under the G20 it would be more affected than the older pre LCI. IF there are price cuts though I'm sure it would affect pre-LCI AND LCI, but probably decrease the LCI prices more since the pre LCI are already so low.
12-07-2018, 05:09 PM | #13 | |
398
Rep 102
https://www.bmwblog.com/2015/05/08/d...-3-series-lci/ |
12-07-2018, 10:01 PM | #14 | |
508
Rep 1,945
Drives: '13 128i, '23 iX M60
Depreciation rates tends to flatten out (or reverse if you’re lucky) the older a car gets.
2023 BMW iX M60 BSM
2013 BMW 128i 6MT MGM/CR. M-sport/Premium/Cold, HK, Xenons, BMW SSK and PE. ED 7-12-2013 SOLD: '07 E90 6MT BSM/Terra, '18 F31 Sunset/Oyster, '21 Polestar 2 http://www.1addicts.com/forums/showthread.php?t=897862 |
IK6SPEED4488.00 |
12-10-2018, 09:02 AM | #15 | |
Guy with a car
98
Rep 224
Pre LCI are say around the 18K-30k and over almost 2+ years ago. Their largest depreciation hit for most models already since most have passed the standard 3 yr range. LCI are at a maximum 2 yrs old. They hold values anywhere from Base Price - say 30k (since that was the pre LCI ceiling). Their value will diminish heavily since there is a whole new chassis coming out rather than a simple face lift and slightly new engine. TDL: Pre LCI cars will not change much in price since their depreciation hit where LCI will depreciate harder from standard depreciation on top of also being an old chassis.
12-10-2018, 09:22 AM | #16 |
5886
Rep 10,256
When buying a used car, depreciation as a factor of great price is actually not the important factor. More important factors are:
- Must have equipment: B58 engine as an example. LCI or not LCI ... - Must have optional equipment - Interior and exterior colors - Vehicle's accident history and mechanical condition - Location and the cost of flying there and driving it back. Many forum members searched for the right vehicle and drove it back a few hundred miles One thing is certain: after 3 years, depreciation curve stabilizes regardless of any new model on the horizon. |
