12-06-2018, 06:19 PM | #1 |
132
Rep 282
saying goodbye to the F30..
most likely.
I had a CEL.. took it in yesterday. today they update me.. have to replace: electric fan: $1130 thermostat/flush cooling system: $650 oil filter housing gasket: $810 coolant expansion tank: $305 so that's around $2800+ I have 4yr/50k warranty too! none of it is covered. wtf. soooooo goodbye. |
12-06-2018, 06:37 PM | #2 |
595
Rep 1,953
Drives: 2013 328i xDrive
You're saying goodbye to a car over $3000? That's not a huge amount of money. I'd understand if there was an extra 0 there..
12-06-2018, 06:45 PM | #3 | |
275
Rep 799
12-06-2018, 06:49 PM | #5 | |||
132
Rep 282
And barely under 83k. |
12-06-2018, 07:17 PM | #6 |
1599
Rep 3,748
3rd party warranty.... need to be read before buying
Dreamvillainz132.00 |
12-06-2018, 07:24 PM | #7 |
132
Rep 282
It was the CPO plan.. the terms are the 2015 one, that's when I got it.
Maybe BMW goes by their new policy of the warranty. Smh. gtfo |
12-06-2018, 07:27 PM | #8 | |
806
Rep 1,906
Break out the tools, none of this work is beyond a person with decent DIY skills, and some willingness to invest time. Good luck/Bill |
12-06-2018, 07:50 PM | #9 |
18705
Rep 14,115
Drives: G82 M4C X-Drive
That doesn't sound outrageous for a german car. Things could be a lot worse. After this, you should be good for awhile.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
12-06-2018, 08:31 PM | #10 |
¯\_(ツ)_/¯
945
Rep 1,762
jeez..... learn how to fix this stuff yourself. Get the parts from fcp euro and buy some tools if you need to and you'll save a ton
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC |
12-06-2018, 08:34 PM | #11 |
¯\_(ツ)_/¯
945
Rep 1,762
electric fan: $1130 (667)
thermostat/flush cooling system: $650 (73 borg warner) oil filter housing gasket: $810 (10) coolant expansion tank: $305 (123) + coolant (20) so that's around $2800+ (893 for all parts....)
Dreamvillainz132.00 Digital_83262.00 |
12-06-2018, 08:34 PM | #12 | |
481
Rep 1,572
12-06-2018, 08:42 PM | #13 | |
18705
Rep 14,115
wrickem2101.00 |
12-06-2018, 09:16 PM | #14 |
8243
Rep 16,082
12-06-2018, 09:23 PM | #15 |
2465
Rep 5,457
Drives: F30
Each and every one of those is a SIMPLE DIY.
Excuse my French but... dont be a moron. Find a decent indy or learn to get your hands dirty. Just trying to be honest! |
12-06-2018, 10:46 PM | #16 | |
132
Rep 282
I'm just mad that the warranty doesn't cover ONE thing. smh. But yeah, we'll see what happens |
12-07-2018, 12:28 AM | #17 |
85
Rep 170
Good indy shop is the way to go, they may even find that a lot of what the dealership is saying needs replaced actually doesn't. DIY is always great, but if you don't have the time or the tools it may be easier just to have a good shop do it for you. Personally my time is more valuable than paying someone who works on BMW's all day and knows what they are doing.
12-07-2018, 01:27 AM | #18 |
1996
Rep 2,499
You have a 2013? The regular warranty is definitely expired. But your CPO is probably still valid. What do you mean by "2015 terms?" Your car is a 2013. You use the 2013 CPO rules. Did the dealership try to say your CPO is limited? Smells fishy.
If the dealership is trying to say your car uses the 2015 rules, they're lying to you. Unless your CPO is expired, which it shouldn't be, but will be close, you should be getting all these things covered by CPO. You have 6 years from the original in-service date of your car for CPO. Period. |
12-07-2018, 07:39 AM | #19 |
95
Rep 279
If it's CPO, you can fight it. You won't always win but it's worth a shot. Dealers have the right to make the call if something is not covered by warranty(even if BMW NA says it's covered) doesn't make sense, but it's true. If you argue enough, they will usually cover some if not all of it. I hate that BMW allows dealers to make individual calls rather than a "on paper" coverage but it is what it is.
Other than that, I agree with the others, indy or tackle the job yourself.
13' F30 335i - BMS Intake -- VRSF DP -- VRSF CP -- VRSF 5" Stepped Intercooler -- Corsa Touring Catback -- JB4 -- H&R Springs -- Miro Flow Formed F25's
12-07-2018, 08:44 AM | #20 |
238
Rep 878
Looking at the parts, I don’t understand what the issue might be, can somebody please explain?
12-07-2018, 08:56 AM | #21 | |
806
Rep 1,906
The shop probably spotted a bit of oil leaking at the OFHG and recommended replacing the gasket - that is a rather common leak point on these motors, and has been going way back 18+ years; saw that issue on my E39's. Replacing the 10 buck gasket can be bit of a pain due to having to remove other components to get to it; sometimes the intake manifold presents problems on this part of the work. He'd be smart to have the tranny fluid changed at his mileage, if he's got an automatic |
12-07-2018, 09:08 AM | #22 |
1303
Rep 1,626
I thought the thermostat has an extended limited warranty? I got a letter from BMW last year saying so, but then mine is a 2012 328i.
2020 M550i (G30) | Carbon Black/Black Nappa | DHP | DAP | Executive | Luxury Seating | Park Asst | Ceramic Controls | Front/Rear Heated Seats | 20" 668M wheels
2021 X3 (G02) | Dark Graphite Metallic/Cognac | Premium | DAP | Front/Rear Heated Seats Sold/Retired: 2012 328i (F30) |
