12-06-2018, 02:10 AM | #1 |
Crazy Frog
543
Rep 1,211
Any power source behind glove box? Trying to hardwire dash cam.
Hello F3X owners.
I'm normally over at E90post with my 11' 328i. This question is pertaining to my GF's F30 328i. I plan on getting her a dash camera for Christmas which I will obviously have to install for her. I was wondering if there is a power source that I can tap into that is located behind the glove box. On my E90, I hardwired my dash cam using one of those "add a fuse" hardwire kits. And it was super easy to use because the fuse box on the E90 is behind the glove box. On the F30 the fuse box is in the trunk and under the hood. Those are not very convenient locations to run wires. If I were to tap into a fuse in the trunk, i'd need a very long wire. I read somewhere that there is a place to tap into power behind the glovebox on the F30, is this true? Thanks guys, and happy holidays.
12-06-2018, 04:11 AM | #2 |
238
Rep 878
There is an accessory port under the glove box that you could use.
12-06-2018, 07:15 AM | #3 |
1307
Rep 1,827
+1
If you get into the passenger footwell and look under the glovebox, you'll see a 12v socket on the left. I have my radar detector hardwired to it.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
12-06-2018, 09:18 AM | #4 |
66
Rep 204
Drives: 2016 428i GC Alpine White
Note that the 12V socket under the glovebox is not switched and at least on my F36 seems to always be on.
2016 428i GC
12-06-2018, 09:44 AM | #5 |
189
Rep 253
12-06-2018, 09:55 AM | #6 |
poopycat
266
Rep 791
12-06-2018, 10:36 AM | #7 | |
66
Rep 204
Does the socket switch on when I open the door (with my fob in the pocket)? Or should it be off then until I turn the ignition on?
2016 428i GC
12-06-2018, 11:00 AM | #8 |
8243
Rep 16,082
I can't say what the under the glove box outlet does, but the center console outlet goes on when the car is unlocked, stays on when the ignition is shut off, turns off five minutes or so after the car is locked.
12-06-2018, 11:05 AM | #9 |
185
Rep 214
I was looking into this as well, but Canadian F30's for whatever reason never came with the 12v socket under the glove box.
Any other option to wire it to something up front? Based on other posts that I have read some ppl wired it directly off another fuse in the fuse box in the trunk. In my E70 X5 I wired it to the constant 12v feed for my map lights and it worked like a charm. |
12-06-2018, 11:40 AM | #10 |
1307
Rep 1,827
Same for the one under the glovebox as well as the one behind the center armrest (below rear passenger climate vents). Fairly certain the one in the trunk as well. I've used it to keep my led work light charged. No excessive drain issues.
12-06-2018, 10:41 PM | #11 |
Crazy Frog
543
Rep 1,211
Thanks guys, I looked today and indeed there was a 12v cig port under there.
12-06-2018, 11:52 PM | #12 |
3788
Rep 5,776
I have my dashcam " hardwired" to the socket under the glovebox. Pretty easy to run the wire along the headliner and under the box for a virtually wireless setup. And yes it stays on for a few minutes after shutting the car off.
01-06-2019, 12:56 PM | #13 |
Rep 18
I took a slightly different approach to installing my dash cam a couple days ago and I'm pleased with:
1. no visible wires, 2. no hardwiring/soldering/permanent connections, 3. being able to use the dash cam in constant or acc power. 4. only took 15min from start to testing. 5. total cost less than $60 US. See pics below. Items on Amazon: 1. REARMASTER Universal OBD Power Cable for Dash Camera,24 Hours Surveillance/Acc Mode with Switch Button 2. APEMAN Dash Cam 1080P Full HD Mini Car Driving Recorder 170° Wide Angle, Motion Detection, G-Sensor, Loop Recording, Night Vision. I gently pushed the dash cam pwr cable up into the headliner along the windshield, down the A pillar and tucked it up under the driver’s foot well with a direct (removable/switched) plug into the OBDII unit (NO Visible Wires). The switch on the plug allows me to easily switch the dash cam into "always powered" for motion detection/theft mode. or "only on with ACC" for standard driving/capture mode. By setting the dash cam's screen saver and motion detection to on, it uses very little battery power when in the "always powered" position (haven't tested it more than 48hrs so far). It's pretty discreet from both the driver's position and outside the car. I'm happy with the video captures, features, options and the plug makes the whole installation so simple, quick, and discreet. |
01-06-2019, 01:02 PM | #14 | |
Crazy Frog
543
Rep 1,211
