12-05-2018, 05:05 AM | #1 |
Rep 5
rear shock absorbers
hi guys had a advisory on one of my rear shock have starting to leak a bit I have standard m sport suspension not adaptive my question is do I replace with oem ones or save th cash and go for aftermarket replacements like Monroe or kyb also is it a case of change the pair or just the damaged one as they sell them singular
12-05-2018, 06:27 AM | #2 | |
2465
Rep 5,457
Drives: F30
I would go with a Bilstein B6 if I were in your situation. I bought my rears (I have B8) for about $250 and installation was VERY EASY. |
12-05-2018, 08:04 AM | #3 | |
81
Rep 552
Shouldn't cost that much and there are plenty around. |
12-05-2018, 10:35 AM | #4 |
143
Rep 242
Drives: 2013 328i 6mt
If you plan on lowering the car I would just go ahead and send it on a set of coil overs. I just finished installing my solowerks.
F30 328i 6mt
Injen, ER, BM3, Solowerks, IND, BMS, BBS E46 M3 smg2 Bimmerworld, H |
sspade2464.50 |
12-05-2018, 11:36 AM | #5 | ||
2465
Rep 5,457
Drives: F30
No reason to though when you can get top of the line aftermarket rears for dirt cheap! |
12-05-2018, 11:38 AM | #6 | |
2465
Rep 5,457
Drives: F30
Just installed Bilstein B8 with AC Schnitzer spring kit and car rides like gold. With new front mounts and all hardware $1275 in parts. Free install. If looking for a cheap replacement... just a set of quality rear shocks will make a BIG difference, I promise! You wont want B8 though unless lowering. B6 is the best you can buy for standard ride height. |
12-05-2018, 01:07 PM | #7 | |
518
Rep 891
Do not replace only one shock at a time, you want front to back weight transfer to not favor one side over another, especially with an open differential.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
sspade2464.50 |
12-05-2018, 01:18 PM | #8 | ||
2465
Rep 5,457
Drives: F30
MacklinUSOB518.00 |
