NCSExpert File Read Question
11-29-2018, 02:11 PM | #1 |
2183
Rep 2,806
Anyone know the difference between codierdaten_lesen and codierindex_lesen?
I read the CAS files using both functions and the codierindex read has more in it.
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
11-29-2018, 04:16 PM | #2 | |
529
Rep 2,503
Coped from a post by FAL. So it should be correct.
11-29-2018, 06:42 PM | #3 |
2183
Rep 2,806
I somewhat figured that but don't understand the distinction between coding index and coding data? I came across this when coding out my self dimming mirrors. I couldn't find anything in the coding data related to self dimming mirrors but it (SPIEGEL_ELEKTROCHROM) was in the coding index file. So I changed the code to not active and coded it in. So now when I pull the file using Coderindex_lesen it shows the dimming feature disabled. Frankly not sure if it works as I haven't driven at night since.
Another difference in the files - the coding index file has the ah of the car's original battery. The coding data file has the ah I coded in when replacing the battery. INPA shows the correct ah of the replacement battery.
11-30-2018, 08:19 AM | #4 |
529
Rep 2,503
I guess that CODIERINDEX_LESEN reads the complete coding options for that index.
When you read data using CODIERDATEN_LESEN you probably only get the coding options equivalent for your vehicle options (FA). Just a guess. This sort of makes sense if you coded your battery incorrectly and just modified the CAS TRC file rather than VO coding the correct ah option for that battery. Just a guess though... |
11-30-2018, 12:05 PM | #5 |
2183
Rep 2,806
That was my guess as well. The only contradiction is that my car has the self dimming mirrors and they are not in the Codierdaten file.
If I get ambitious I'll change the VO to the correct battery ah and see if that shows up in the Codierindex file. Even if it does, still doesn't explain why the mirrors aren't in the Codierdaten file.
11-30-2018, 02:10 PM | #6 | |
529
Rep 2,503
11-30-2018, 03:05 PM | #7 |
2183
Rep 2,806
The index trc file is much bigger - 234kb vs 8kb. I pulled the index trc file for the NFRM and it is the same size and probably the same file as the index trc file pulled from the CAS.
So maybe the index files are everything from the VO. I say that b/c that file has the car's original capacity battery. Except I can't find mirrors anywhere else. Probably no surprise - when you just use the Read ECU function it pulls the same file as Codierdaten Lesen. This isn't a real problem for me as all prior coding is working, but, I'd like to understand how this works.
11-30-2018, 03:43 PM | #8 |
529
Rep 2,503
This makes sense. CODIERINDEX_LESEN is likely a global job. No matter what ECU you select the entire coding index is read as per the vehicle order. This job is run when you run NCS after choosing a chassis. When the VO and VIN etc is populated a FSW_PSW trace file is populated with the complete coding data. It surely must be the same/similar process?
11-30-2018, 03:47 PM | #9 |
2183
Rep 2,806
Except I can't find the mirror functions outside of the index file. Admittedly I haven't read every module. Must be somewhere else.
11-30-2018, 03:56 PM | #10 | |
529
Rep 2,503
Fold-in Outsider Mirror: $313 Interior/Outside Mirror with Automatic Dip: $430 Interior Mirror with Automatic-Dip: $431 That coding option is normally in the NFRM. There is also: EC_SPIEGEL in the FZD. I know you don't need to know this though. |
11-30-2018, 05:24 PM | #11 | |
2183
Rep 2,806
I'm very frustrated I can't figure this out even though it's not important now. Hopefully someone is reading this thread who has gone thru this.
12-01-2018, 01:41 AM | #12 | ||
529
Rep 2,503
Are you 100% it's not there? |
12-01-2018, 11:10 AM | #13 |
2183
Rep 2,806
Only if I pull the file as Codierindex_lesen. Not when pulled as read ECU or Codierdaten_lesen.
12-01-2018, 11:58 AM | #15 |
2183
Rep 2,806
Car is 2013 E82. Not sure about the FRM but NCSE show as NFRM.
12-01-2018, 12:44 PM | #16 |
2183
Rep 2,806
Here is a shot from INPA that I hope shows what version of FRM my car has. Obviously, I don't know a lot about this.
12-01-2018, 05:04 PM | #17 |
529
Rep 2,503
So you have FRM3. In FRM many things changed. The function SPIEGEL_ELEKTROCHROM is actually ASP_ELEKTROCHROM and is in your FRM3 module.
Why does SPIEGEL_ELEKTROCHROM get included in your index file? I don't really have any idea. Maybe in early FRM3 datens SPIEGEL_ELEKTROCHROM was correct and then it changed in later revisions. Was The FRM3 factory or a retrofit? As SPIEGEL_ELEKTROCHROM is 1000000% in the FRM2 not CAS. |
12-01-2018, 07:20 PM | #18 |
2183
Rep 2,806
Aha! ASP_ELEKTROCHROM is in my FRM daten files. I haven't been using NCSDummy so had no idea what ASP was. I only searched for SPIEGEL.
The only thing I can think is that the Index files are everything that can possibly be present in a module's coding and the daten files are what are actually enabled. Big mystery that I'd like to solve. So I'm assuming the not active I coded in the Index file did nothing to change the mirrors since that line isn't in the FRM module. Thanks for all the help on this one. The FRM is original to the car.
