CCC to CIC retrofit coding issue
11-21-2018, 10:10 AM | #1 |
105
Rep 544
Recently decided to do this retrofit since it seemed straightforward. Everything connected easily as the write ups say but the coding part having issues. Im able to FA write the CAS and NFRM w/ #0910 $609 $6VA. But when I go to add SG_Corden to CIC I get an error won't let me do it
Any ideas where maybe I went wrong or maybe is a NCSexpert/Edibas setup issue. Any help would be appreciated. Last edited by FEDE/E92; 11-21-2018 at 10:49 AM.. |
11-21-2018, 10:15 AM | #2 | |
263
Rep 1,173
11-21-2018, 10:23 AM | #3 |
105
Rep 544
Thank you so much for the quick reply. The CIC seems to power on but no screen. I didn't see a popup with NETTODAT when i was connected.
11-21-2018, 10:30 AM | #4 |
263
Rep 1,173
When in NCS, see if it will let you "read" the CIC, then the NETTODAT should pop up. If it errors there as well, then you have hardware install issues.
11-21-2018, 10:40 AM | #5 |
105
Rep 544
Same error as before popped up. Not sure what to do, i had somebody remote install this a year ago.
11-21-2018, 10:50 AM | #6 |
105
Rep 544
