Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Alpina B3 Flash Error
      11-18-2018, 01:11 PM   #1
mweisdorfer
mweisdorfer's Avatar
1903
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
I have trans number 7591971
Using WinKFP to do the Alpina Flash.
Selected 7615835 as the number I wanted it to switch too from my daten files. I have the latest one v65 from June 18'.
So, enter in my vin number, hit done
Hit program & I get error 201
7566854 bsu not possible.
I have the GS19.11 TCU module according to INPA.
I don't get it....???
Using WinKFP 5.3.1 I got on Bimmer geeks & using the cable I got from Rheingold.
Please Advise....
      11-18-2018, 03:33 PM   #2
LMB335IS
Sua Sponte
LMB335IS's Avatar
1299
Drives: 2013 LMB 335is
2013 BMW 335is  [8.84]
Post 03/07 production date? You should be using GKE215 as your ECU.
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
      11-18-2018, 04:32 PM   #3
mweisdorfer
1903
2008 bmw x5  [0.00]
Yep. Did that.
I do have a 01/07 production date, but INPA says I have the updated TCM that has 1gb of memory.
So, I don't know....
I guess I'll have to look into xHP
What GKS should I use if I am just prior to 03/07?
      11-18-2018, 04:36 PM   #4
LMB335IS
Sua Sponte
LMB335IS's Avatar
1299
Yep. Did that.
If you're sure you have the right TCM, you could try changing the prod date in your VO to a later date. Maybe your old production date is causing the error.
I'm just throwing that out there. I dont know if that's the problem but XHP is a better overall solution anyways, just not free.
      11-18-2018, 05:10 PM   #5
mweisdorfer
1903
2008 bmw x5  [0.00]
Yep. Did that.
I Hear ya. It's just a little frustrating. I have the right numbers for the transmission, & the bigger TCM & no dice.
      11-18-2018, 08:58 PM   #6
lucasmiller2015
76
Drives: 2020 M340i
2011 BMW 335i  [0.00]
Please Advise....
You can use the xHP app (without buying any licenses) to verify which hardware you have
2020 M340i | Mineral Grey Metallic | Premium | Exec | Adaptive M Suspension | Harmon/Kardon
Previous: 2011 E90 335i | Black Sapphire Metallic | 2007 E90 335i | Monaco Blue Metallic
      11-18-2018, 09:42 PM   #7
Levanime
BimECU
Levanime's Avatar
193
Drives: BMW
2007 BMW 335  [0.00]
alpina will not work on pre 03/2007
so as said above, xhp is the way
      11-18-2018, 10:36 PM   #8
lucasmiller2015
76
Drives: 2020 M340i
There are some exceptions to the 03/07 cutoff, and OP may have one of those.
      11-19-2018, 04:08 PM   #9
mweisdorfer
1903
2008 bmw x5  [0.00]
I'm pretty sure I do, but I think I have to change the date in my VO to the TCM.
I'm a little hesitant to do that...
Has anyone done this ?
      11-21-2018, 09:55 AM   #10
Joe@TopGearSolutions
Joe@TopGearSolutions's Avatar
263
Drives: BMW
The transmission module does not store the VO, so I highly doubt changing the production date in the VO will solve your issue.
The only way for a pre 03/2007 to have the alpina flash is to change out the module from a post 03/2007 tranny. Or, change out the tranny all together.
Using WinKFP, you can read the UIF from the transmission module and double check the software numbers you currently have. But, I'm afraid it will lead you back to a tranny that's not compatible with the alpina flash.
      11-22-2018, 04:11 PM   #11
lucasmiller2015
76
Drives: 2020 M340i
I have a post-03/07 TCU that I'm not using (sold my '07 before installing it). I'd let it go for cheap, so let me know if you're interested.
Original sale post here: https://www.e90post.com/forums/showthread.php?t=1393674
      11-22-2018, 09:08 PM   #12
mweisdorfer
1903
2008 bmw x5  [0.00]
How much ?
