2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Mechanical Maintenance and TSBs: Break-in | Oil & Fluids | Servicing | TSB is it worthwhile to chang out coolant?
      11-13-2018, 06:40 AM   #1
buster-riley
26
Drives: 2016 m235i 6MT no sunroof
I have only 20K miles on my 9/2015 build date m235i. does coolant change prevent trouble later with electric coolant pump etc? If so do you change it out based on time or milage?
      11-13-2018, 03:59 PM   #2
B58togo
809
Drives: M240i
I plan on doing mine around the three year mark. I’ll be around 50k by then, but if you’re at three years, regardless of mileage, it would be wise to do it soon.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
      11-13-2018, 04:35 PM   #3
overcoil
3074
Drives: M235i 6spd
I’m coming up on to 4-1/2 years still under 35,000-miles. Will probably get a refractometer or hydrometer (I’ll research if they work on these long life coolants) and test my coolant before the temps drop into single.
I’ll also check my hoses and think about changing out any hoses that have easy access.
      11-14-2018, 07:43 AM   #4
MarcoZandrini
444
Drives: 2018 M240i
I highly recommend that the cooling system be drained, flushed with distilled water and refilled with a 50/50 mix of BMW and distilled water every 3 years. These cars, especially those with a turbo, are hard on the coolant. Btw, I’ve owned and wrenched on bimmers since 1974.
      08-01-2019, 12:56 AM   #5
MiamiM235iEstorilBlue
61
Drives: 2016 m235i
never heard of mixing 50/50. Is that normal practice? Is it a Bad idea to just refill with 100% BMW coolant?
      08-01-2019, 04:31 AM   #6
overcoil
3074
Drives: M235i 6spd
Usually the coolant bottle will have a chart that gives % of water to coolant for the maximum minimum temp ranges you’ll see.
I actually believe water is a better heat exchanger then anti-freeze but in cold temps water will freeze and water doesn’t offer the anti-corrosion. And water converts to steam at too low a pressure so anti-freeze helps with system pressurization.
Jay Leno talks about a radiator fill that has neither the need for water and is not glycol based - it’s main attribute is long life and no corrosion for cars that have a long life 100 years, it’s a classic car savior.
      08-01-2019, 08:48 AM   #7
aerobod
Car Geek
aerobod's Avatar
3626
Drives: Caterham R500, M2-G87, Macan S
Many coolants from parts stores are already pre-mixed 50/50 with water, it should say on the bottle. BMW coolant from the BMW parts dept is not generally pre-mixed.
It is a very bad idea to fill with 100% coolant as the engine will likely overheat due to poor heat transfer in typical summer conditions and in very cold conditions the coolant will freeze sooner than a 50/50 mix with distilled water.
      08-01-2019, 12:43 PM   #8
John in VA
985
Drives: 2015 228i M Sport
Agreed - 100% coolant is never a good idea.
There are paper "dipsticks" & gauges that can test the acidity of your coolant to let you know if it should be flushed.
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining
      08-11-2019, 03:26 PM   #9
61
Drives: 2016 m235i
Im not finding many DIY's for the M235i at all. Are most things very similar to the 435i/335i?
How hard is the car to flush properly for a shadetree DIY person?
      09-05-2019, 02:45 PM   #10
biz4two
15
Drives: 2014 f22 n20 228i
Arrow
Try to focus on the type of engine you have not the type of car you have. So, search for N55 coolant flush, etc. YES, the N55 in the 435i is identical or nearly identical to your M235i. Small variations from year over year, but pretty darn close. Especially when wanting to perform a coolant flush.
biz
2014 BMW 228i f22 n20
Prod.date: 2014-06-27
      11-07-2019, 07:18 PM   #11
123Britt
289
Drives: 15 M235i AT
1/2 Life on Everything
BMW says 100K Coolant then change it at 50k.
BMW says 10K oil change then change at 5K
BMW says 100K AT Fluid then change at 50K
Simple and effective for Long Long Long Term ownership. If you plan on selling the car before 100K mile then just follow BMW Std change intervals.
WolfGTI716.00
2addicts
