e91 330d totally confused with which rheingold software I need
10-28-2018, 09:28 PM | #1 |
Rep 4
Sorry if this is a repost but I am not getting anywhere with my research for Rheingold, ISTA/P or whatever its called (there are about 16 different names used to call this software).
Basically ill own a 2006 bmw E91 330d soon and I would like to have the factory service manual for it as well as a way to check and clear codes. If the program can monitor engine/chassis parameters in real time that would be great too. Thats pretty much it, I dont really care to program it or recode anything. I understand, i think, that ISTA/D is the factory BMW diagnostic/service manual software that achieves this? But which version, and or who can I buy it from that is reputable and wont lead to damaged ECM's?? It seems to me that there are many many many different versions of this software, too many to count, with absolutely NO INFORMATION about what the differences are between them. Does this software require a login or a registration key? I would greatly appreciate assistance on this, what works for you guys? |
10-28-2018, 11:44 PM | #2 |
1911
Rep 13,104
The one at Bimmergeeks.net is pretty current
I think. This works for the gas cars not sure about the diesels. Should be more than adaquate in terms of being recent for and 07. They also make one of the better K/D can cables. Install instructions are usually in the downloads. There are many threads on doing the install here. The way you update it is add the new daten files with BMW standard tools. you need to start reading a lot of the ista threads here. diagnostic manual ista/inpa https://bimmerprofs.com/diagnostics-inpa-part-1/ https://www.google.com/url?sa=t&rct=...xo19teM9vkTF-C https://www.google.com/url?sa=t&rct=...7x8H3pN8h1fMuF Ista is very fault tolerant it won't allow you to do stupid stuff whereas Inpa, ncsexpert and tool32 will. The only time you stand a chance of damaging ECM's is when programming. You need Ista P to program an big power supply and maybe and Icom cable to to that. You can code with ncsexpert which is a little different than programming and entire module. You can also program individual modules in ncsexpert . Ista p is what you use to update the entire software for the car. Last edited by ctuna; 10-29-2018 at 12:18 AM.. |
10-30-2018, 12:15 AM | #3 | |
2697
Rep 4,031
INPA works for me, and either INPA or ISTA would work even better for you if you speak German (in Germany most do ;-) I use INPA to: 1) Read Fault Codes (Fehlerspeicher Lesen), Read Freeze Frame Details or InfoSpeicher, and Clear Fault Codes (Fehlerspeicher Loschen); 2) See Live Data or Parameters (Status); 3) Activations (Steuern) such as to run the fuel pump, radiator fan, coolant pump, etc. First, you need the Daten files for the E89 for your E91. The ~ 20 different ECUs (Control Modules) in your E91 are basically the same as any other non-diesel model, EXCEPT you have the DDE (Digital Diesel Electronics) Engine Module rather than the DME used in gasoline-powered engines such as the N52, N54 or N55. I'll attach a screen print of the INPA Script Selection Listbox that shows the various DDE/DME choices in the next post to this thread, so the jpg file won't ruin the page width. Remember, the DME/DDE is just ONE of ~ 20 different Electronic Modules INPA or ISTA can connect to, choosing from similar listboxes, for such Modules as the EKP (fuel pump module), CAS, DSC, IHKA (Climate Control), EGS (Transmission), VGSG (Transfer Case), etc. If you go to the following site, you can download INPA in the BMW Standard Tools group, or Rheingold for ISTA. If you don't have a K+DCAN cable, you can get one from the same site (BimmerGeeks), from Amazon, or any similar online retailer. BMW-Specific Diagnostic Software, INPA (Standard Tools), ISTA (Rheingold): https://www.bimmergeeks.net/downloads BimmerGeeks Pro K+DCAN Cable: https://www.bimmergeeks.net/product-...eeks-pro-cable TIS Online Service Manual: https://www.newtis.info/tisv2/a/en/ Please let us know your experience, George |
Bmwneedsworkagain14.50 |
10-30-2018, 12:16 AM | #4 |
2697
Rep 4,031
See Attached DDE Selection in "Engine" Listbox in INPA per above post. The filename reflects the DME in my N52KP E91.
If you have a Diesel, you would select one of the DDE Engine Control Modules. George |
10-30-2018, 05:50 AM | #5 | |
1231
Rep 1,101
10-30-2018, 01:34 PM | #6 |
1911
Rep 13,104
Do you have a cable yet?
What are you using for a computer ? Which operating system does it have? These programs are sensitive to where you setup the file structures. There are also settings for the cable and some active x controls that may have to be setup and registered. Both Ista and Inpa use the same base program for routines it may be easier to get Inpa working first. |
10-30-2018, 01:47 PM | #7 | |
2183
Rep 2,806
Got frustrated and gave up.
E82 / BMWP Springs / Koni Yellows / M front control arms / Adjustable front endlinks / M rear guide rods / Whiteline Poly RSFB
10-30-2018, 10:35 PM | #8 |
1911
Rep 13,104
http://blog.obdii365.com/2017/11/16/...nstallation/#1
There are some installation instructions that I thing will still apply in the above link. So just to see if I could still do it and to get it on my new PC I downloaded the Bimmergeeks Inpa and Ista setup on my newer Lenovo 910 running the latest windows 10. And got it working Some things to note on Windows 10 the cmd prompt to run as administrator is called the Power Shell now and there is an Administrator version to. I had to use this to get the Administrator version to load the active x controls successfully And to launch ista I had to right click and run as admistrator to launch ista. This is described in the instructions that bimmergeeks provides if you just follow them . Following them to the T is key as computers are unforgiving. Make sure you install all the programs in the Pre-Install folders to. Ista D has a message if you don't run it as administrator something about invalid version. Also ista has a sizing problem for my hi res screen and since you can't resize or move the window around it can be frustrating. I moved my toolbars to the side to make it pretty usable. Set the resolution on the screen one size down everything is golden now. Last edited by ctuna; 11-02-2018 at 06:59 PM.. |
12-05-2018, 08:32 AM | #9 |
Rep 4
Update: I purchased a software package called "Original Kdcan Pro Interface Diagnostic Tool for BMW INPA Rhein Gold, NCS Expert" from amazon.de and everything worked GREAT.
They send you all the cables you need, high quality i might add, and then a username and password for their website. You then download all of the software that you want (and if you can read german there are additional programs for free- "Dr.Gini" for example which can display all engine parameters in gauges very easily). I have read my 2006 330xd with it as well as a 2008 E61 530xd. Works flawlessly. To anyone that reads this: dont take a chance downloading sketchy and free software, just find a reputable product and just spend the money. Well worth it. At least it was for me. |
12-06-2018, 12:17 PM | #10 |
529
Rep 2,503
All the software on the bimmergeeks website works fine.
There is no need to buy this software from anyone. People who sell this software probably downloaded it from bimmergeeks or a Russian forum |
