mpg gauge to temp gauge
10-24-2018, 03:05 AM | #1 |
Rep 15
Hello,
I have problem with coding temperature gauge instead of mpg. I have found instructions on this forum how to do it but it stops on first step. I am attaching the instructions which have found here and the photo of my program. On photo are CODIER DATEN with FF inside but it should be like in instructions numbers and letters on page 2 of instructions. How to fix that if someone knows? Thank you in advance. |
10-24-2018, 08:26 AM | #2 |
529
Rep 2,503
You have choose the most difficult way to do it.
I suggest you to download Perfekt Toolbox. It's much easier. Also, some engines are not compatible. What engine do you have? |
10-24-2018, 11:37 AM | #3 |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
Will it work on a M57 335d?
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
10-24-2018, 03:27 PM | #4 | |
529
Rep 2,503
That seems to be the general consensus. |
10-24-2018, 03:36 PM | #5 | ||
Sua Sponte
1299
Rep 2,850
10-25-2018, 03:54 AM | #6 |
529
Rep 2,503
I believe they have different DDE control units. After 2008 onwards for some reason the DDE software stopped broadcasting the temperature over the CAN on 0x1D0. Which is what the instrument cluster looks for.
The US only got the 335d in 2009? Even though it's still an M57 it's slightly different than the euro version. However, you can use a piggy back device to hijack and send the temperature signal on 1D0. This has been done and works well. You'd need to disable some fault codes though via a custom tune. |
LMB335IS1299.00 |
10-26-2018, 02:29 PM | #8 | |
Robot
1685
Rep 2,191
I found this which might help: https://cartechnology.co.uk/showthread.php?tid=33202 The last attached picture shows the window for programming fuel consumption and has five values for motor steps. I'm assuming these steps correspond to the position of the motor that controls the needle on the gauge. It looks like the 0/444/888/1333/1777 which corresponds to the position of the marks on the gauge cluster. For example, if the car is currently consuming 5.4 L/100km the gauge needle motor would go to the 444 position. So I would think that you would enter those same values for motor steps (0, 444, 888, 1333, 1777) and then for the five values above you would specify what oil temperature you want to correspond to those points on the gauge. I have no idea what works best, or what nominal engine oil temperature is on the 328. I read 210-240 is normal, so maybe put 225 in the middle position and go with 185/205/225/245/265 to start? You also might need to use a lower damping factor than what's specified for the fuel consumption screen (it was 13 at that link I shared), I'm thinking that oil temperature changes aren't going to be as sudden as fuel consumption changes. Just don't blame me if something goes wrong. |
E7J3F331.00 |
10-29-2018, 10:06 AM | #9 |
Rep 15
I see yes, thank you for answer and solution to make this happen. But what can go wrong? I will have to write in degrees. I am thinking about to go from 60-80-100-120-140 degreese or make it more specific and less range from minimum to maximum?
11-24-2018, 03:20 PM | #11 |
Save the manuals!
6015
Rep 6,746
I did 0, 50, 100, 150, 200 (in degrees Celsius not Fahrenheit). It matches up well with the intervals on my Canadian L/100km fuel economy gauge.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
lowrydr3101684.50 |
11-26-2018, 12:28 PM | #12 |
Robot
1685
Rep 2,191
I should have caught that, you're right in using degrees Celsius (should probably do the same on my US car because all calculations seem to be done in metric units then converted just for display)
