Do i really need Windows XP for BMW Tools?
10-19-2018, 04:45 PM | #1 |
113
Rep 513
Drives: 2008 335i
Is it worth dual booting my computer with windows XP to run BMW tools from bimmergeeks website?
10-19-2018, 05:23 PM | #2 |
626
Rep 2,099
Just easier. But people run Windows 7 or 10 with VM on it as well. There's a tutorial here somewhere.
I think even Bimmergeeks had an instruction how-to on their site...maybe I'm wrong. |
10-19-2018, 06:38 PM | #4 |
BimECU
193
Rep 759
u can run it on windows 10 without vm
10-19-2018, 07:11 PM | #6 |
996
Rep 2,287
Ya, the days of needing windows XP are thankfully long gone.
Bimmergeeks.net is one of the best downloads to use. |
10-20-2018, 04:56 PM | #8 |
113
Rep 513
Drives: 2008 335i
Thanks, guys, I'll persist with windows 10 and compatibility mode then. Cheers
11-04-2018, 01:11 PM | #10 |
1911
Rep 13,104
Just did a install of Bimmergeeks links for Inpa and Ista d
on a Win 10 computer. A couple of things to note The command prompt is called the Power shell in win 10 and it has two versions use the run as admin version. To start ista you must use the run as admin option every time to open it. Any way to make this the default selection in the desktop link. This is in the instructions. Even though I had admin privileges in my login I had to use the run as admin selection. Looks like win 10 home is not very friendly to admin privileges. Last edited by ctuna; 11-04-2018 at 11:19 PM.. |
11-05-2018, 11:09 AM | #12 |
113
Rep 513
Drives: 2008 335i
I got it all working on windows 10 using compatibility mode using the instructions included in the bimmergeeks download pack.
What I was missing was the daten file download that you also need, it's a huge download. Oddly enough, folks don't mention these files, but in passing. It should be included in the tools download, but i get it, it's a big download and car specific too. |
11-05-2018, 11:53 AM | #14 |
Basic Bimmer
518
Rep 935
Drives: E92 328i 6MT ///M
ctuna I believe you can either right click on your shortcut or on the program itself (that the shortcut points to... for example, the shortcut to open the app that is located in the start menu) and somewhere in those options is a place where you can tell it to always open with admin rights. Then you'll just have to click "yes" each time you open the program when it asks if it's allowed to modify the computer.
Black Sapphire 328i ///M Sport Coupé Save the Manuals! |
11-05-2018, 01:01 PM | #15 |
1911
Rep 13,104
Yeah I figured out how to get it running in admin mode by
right clicking my ista shortcut and selecting run as admin , but why should I have to . Then I discovered something about the home version of Win 10 64 and Win 10 . It doesn't like you to have admin privileges even in your own login. The users option is absent from the computer management screen an you have to go in through the backdoor (cmd prompt or power shell to set it up different) Its not a big problem to do the right click thing as much as I use ista but it bugs me that I have to at all. From what I read Microsoft did this to keep thing safer. The Pro version of Win 10 is a little more friendly to this but I not sure if it solves the problem either . What would be nice is to somehow default the shortcut to always run in admin mode. Also most people will only download the base and the chassis files for there car from the mega daten link, which isn't so big. Last edited by ctuna; 11-05-2018 at 01:52 PM.. |
11-05-2018, 01:29 PM | #16 | |
Sua Sponte
1299
Rep 2,850
Drives: 2013 LMB 335is
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
04-07-2023, 05:06 PM | #17 |
Rep 1
It really depends on how important BMW Tools are for you. If you need them frequently, then it might be worth setting up a dual boot with Windows XP. However, if it's just something you might use occasionally, you could also consider running Windows XP in a virtual machine.
04-07-2023, 05:55 PM | #18 |
Rep 2
Apologies for reviving this old thread, but I couldn't resist chiming in. It really depends on your specific needs and how much you rely on BMW tools for your car. While Windows XP may be an older operating system, it's still compatible with BMW tools, and some people find it easier to use for these specific programs. However, dual booting can be a bit of a hassle and may not be worth it if you don't use the tools frequently. You can also check out the reddit buy windows communities to get more tips and tricks from users and find license keys and software updates. Ultimately, it's up to you to weigh the pros and cons and decide what works best for you.
04-08-2023, 02:09 PM | #19 | |
185
Rep 780
04-19-2023, 04:13 PM | #20 |
43
Rep 130
+ WinXP is very light and compact if you have multiple VMs. Desktop is very responsive.
- WinXP can be unstable with some drivers etc. - WinXP image is harder to obtain than Win10 For VMs I would recommend XP if it's supported by the software just because how little the operating system itself takes space. For space of win10 installation you can likelly fit both winxp + tool package in most cases. |
04-19-2023, 11:18 PM | #21 |
apktome
Rep 2
i think out of windows versions i find win10 is the best one to use and i have also tried some versions like win7 and win11 and found win 11 has certain errors or you can go right here to find and download some versions that you need
