Coding of DSC and DME
10-14-2018, 02:23 PM | #1 |
Rep 18
Is it advisable and/or possible to code your DME and DSC with an empty MAN file via NCS?
I do understand it is normal to do so for the media box, FRM, CAS, etc. Though I do not read about doing this to a DME. I have successfully updated my DME and DSC via WinKPF and thereby resolved the N47 injector zero calibration issue. Though not sure if coding it empty is necessary or risk full. Considering this since I am left with one returning error code: A0B1 SG input P N, which was not there before updating the DME, CAS AND DSC. I have got to remark that the CAS module had been replaced as well during the update and also did not get recoded empty MAN to standard VO. Please advise. Thanks. Last edited by lrklrk; 10-14-2018 at 02:28 PM.. |
10-14-2018, 02:38 PM | #2 | |
529
Rep 2,503
But.... You don't do this with blank MAN files. This is not the correct way. You should be use an expert mode profile in NCS without manipulation. Then code the module as normal using the job SG_CODIERDATEN. |
10-14-2018, 03:54 PM | #3 |
Rep 18
Ok, thanks for the quick reply. I normally use the revtor profile, which then If I understand correctly is only ment for manipulation of settings?
Am I correct saying that by using a manipulation disabled profile NCS takes its setting to code from the SP daten? Also In some instructions is mentioned for pre 02 cars to use sg codieren and for post 02 fa write. I do not quite understand that. |
10-14-2018, 04:25 PM | #4 | |
529
Rep 2,503
Basically your car has a vehicle order (VO). In Deutsch, this is FA. This is a list of all the different option codes you have and is stored in the CAS and a backed up in the FRM. Each module has many different coding options depending on your FA/VO. The module coding settings will be set to their default from factory. If you change an option or piece of hardware on your car you shouldn't just go to the module in NCS and change the coding directly. The correct way is to add/takeaway the correct VO code to FA/VO list the code the relevant module/s to the new FA/VO by using an expert mode profile (no manipulation. There are many guides on how to do this. The FA write command is to change the FA/VO list. |
