BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > UK > UK Classifieds Section > FOR SALE: 4 pot 370mm / 2 pot 345mm Blue Brembo M Sport Calipers (used, with pads)
      10-02-2018, 12:01 PM   #1
R99
1099
Drives: 2016 330d F31 Touring
Hi all,
For sale is a set of blue Brembo M Sport brake calipers. These are the larger versions found on the higher powered F3x models.
These can also be fitted to E9x models, as extensively documented here: https://www.e90post.com/forums/showthread.php?t=828362
The kit consist of:
2 x 370mm front calipers
2 x 345mm rear calipers
No discs / rotors are included, this is a sale for calipers only with used pads left in and the associated pins and clips.
These brakes are used, but in a great overall condition. The fronts have a couple of tiny marks and the rears also have a few marks, which would benefit from a touch up. There are also some marks on the back sides of the calipers, which will obviously be invisible once fitted. Please see the attached images to satisfy yourself of the condition.
The pads are aftermarket variants made by Apec and have loads of life remaining, see pics.
The bleed nipples are free moving, as are the pistons which pushed back by hand without issue.
Price: £699, plus shipping costs.
International shipping isn't a problem, please PM me and I will obtain prices for you.
Pics...
      10-02-2018, 01:02 PM   #2
Phil325i
Phil325i's Avatar
616
Drives: E92 325i MSport Coupe
Haven't read all 65 pages of the thread you posted (!) but I assume these need 19" wheels for clearance..?
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
      10-02-2018, 01:04 PM   #3
R99
1099
Not necessarily! I currently have the 370’s under 18” on my F31.
If you have 18” OEM E9x wheels though then chances are you would struggle with clearance.
      11-06-2018, 11:26 AM   #4
R99
1099
Another of of these for sale.....
https://f30.bimmerpost.com/forums/sh....php?t=1552461
