Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Is this possibly due to low voltage?
      09-24-2018, 09:52 AM   #1
ob23
Drives: 2008 bmw 335i convertible
Hi I was checking out a bmw 335i 2008 convertible that I wanted to buy. I got it inspected and th emchanic said that there were an abnormal amount of fault codes appearing such as abs, dsc, airbag, brake pads, and fuel pump codes. He erased the codes and checked again and nothing came back. He thinks it might have been fue to low voltage previously from maybe the battery and such causing wrong error codes. The car drives fine and everything seems to work. What is your take on this, also would it take some time before the fault codes came back if they are an actual issue?
      01-09-2019, 02:52 AM   #2
Doesha
30
Drives: 2006 330i Pre-LCI Monaco Blue
weak/bad battery would cause faults like this.
