09-16-2018, 03:42 AM | #1 |
Rep 8
Navigation infos doesnt show up on cluster
Hi people,
I have nbt installed on my f30. when I set a route and when route wants me to turn it doesnt show up in cluster but I saw it showing up in a diffent car Do I have to enable something? Or coding required ? ( if it is please give me the codes to change if possible ) Thanks for your attention. |
09-17-2018, 05:39 PM | #2 | |
130
Rep 765
09-19-2018, 08:20 AM | #5 |
No 55mph
1622
Rep 8,476
HUD = Heads Up Display
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
09-20-2018, 03:00 AM | #8 |
538
Rep 1,201
Did you only retrofit the navigation and not the 6WA cluster? You need the 6WA cluster to show navigation directions. Your car probably only has basic kombi if it didn't have navigation.
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD) |
09-21-2018, 09:11 AM | #9 | |
Rep 8
https://4.bp.blogspot.com/-FwSump703...25282%2529.jpg |
09-21-2018, 09:31 AM | #10 |
Rep 8
I haven't but I will, is that the codes I should change ?
and if there are some missing or extra codes can you tell them ? KOMBI L7_MID > Anzeige_Konfiguration 3000 > NAVI_NBT_ENABLE = kein_nbt [Default] KOMBI L7_MID > Anzeige_Konfiguration 3000 > NAVICOLOR_TABLE = alte_farbtabelle [Default] KOMBI L7_MID > ERM_Konfiguration 3004 > DISP_DCRN_ASST_APPL = nicht_aktiv [Default] KOMBI L7_MID > FZG_Ausstattung 3003 > HUD_ENTERTAINMENT_MOST_ENABLE = nicht_aktiv [Default] KOMBI L7_MID > FZG_Ausstattung 3003 > HUD_NAVI_ENABLE = nicht_aktiv [Default] KOMBI L7_MID > FZG_Ausstattung 3003 > NAVI_VERBAUT = navi KOMBI L7_MID > FZG_Ausstattung 3003 > VZA_ENABLE = nicht_aktiv [Default] KOMBI L7_MID > PIA_Einheiten 3008 > HUD_PIA_NAVI = nicht_aktiv [Default] KOMBI L7_MID > PIA_Einheiten 3008 > KI_PIA_ANKUNFT = aktiv KOMBI L7_MID > PIA_Einheiten 3008 > KI_PIA_DISTANZ = aktiv KOMBI L7_MID > PIA_Einheiten 3008 > KI_PIA_NAVI = aktiv HU_NBT > EXBOX 3001 > KOMBI_CIC = kombi_mid HU_NBT > EXBOX 3001 > SETTINGS_INFO_DISPLAY = aktiv [Default] HU_NBT > HMI 3000 > BASIS_KOMBI_MMI_LIST = nicht_aktiv [Default] HU_NBT > HMI 3000 > HIST_GAS_CONSUMP = aktiv HU_NBT > SYSTEM_EINSTELLUNGEN 3004 > EXTERNE_MOST_DIAG = aktiv HU_NBT > SYSTEM_EINSTELLUNGEN 3004 > EXTERNER_MOST = aktiv |
09-22-2018, 09:29 AM | #11 | |
130
Rep 765
