TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Right Cornering Light Malfunction error code
      09-10-2018, 07:09 PM   #1
DYOOS
DYOOS's Avatar
88
Drives: 335i E90 N55
Got this error code after going FBO. Tried searching for a solution, but came up short since they were different "light malfunction" errors. Anyone know how I can get this resolved?
I'm thinking it's just a lose connector or bad bulb.
IG: @dyoos335i
      09-10-2018, 08:28 PM   #2
rulermark
Drives: 335
thats the h1 bulb in the headlight housing
      09-10-2018, 08:43 PM   #3
DYOOS
DYOOS's Avatar
88
Is that the inside light bulb (the one closer to the grill)?
IG: @dyoos335i
      09-13-2018, 10:55 AM   #4
apexit4
Poland
1231
Drives: 335D M-Sport, X5D
Im not so sure this is the H1 bulb. I have a similar warning on my car and after verifying that all the lights and bulbs work, have been led to believe the actual issue is the "adaptive" steering portion of the lights that pivot in the direction you are turning the steering wheel.
      09-14-2018, 02:03 PM   #5
rulermark
Drives: 335
There is a H1 bulb on the lci with adaptive in the inner part of the light that turns on when you have the turn signal on or turn the wheel in that direction. to get access see top of headlight see the panel with the 3 screws its right in there.
DYOOS88.00
      09-14-2018, 10:57 PM   #6
DYOOS
DYOOS's Avatar
88
Any recommendation on what brand H1 bulb to get? For what it's worth, I have the Lux H8.
IG: @dyoos335i
      09-15-2018, 01:29 AM   #7
rulermark
Drives: 335
Apologies for calling it an h1 I get the two mixed up all the time, it's actually an h3. See these threads, https://www.e90post.com/forums/showthread.php?t=647325 https://www.e90post.com/forums/showthread.php?t=823508
      09-15-2018, 01:56 PM   #8
DYOOS
DYOOS's Avatar
88
Looks like GP Thunder 7500 H3 bulbs are the way to go.
IG: @dyoos335i
      09-16-2018, 06:45 PM   #9
DYOOS
DYOOS's Avatar
88
Just replaced the H3 bulb and haven't gotten the error. All looks good for now.
IG: @dyoos335i
      01-15-2019, 07:48 PM   #10
Nickolma
Drives: BMW E90 330i
I had a similar problem but it was my smc lear module. Water had gotten into it and it had corroded. Scored one off eBay for $100.
      09-25-2023, 05:05 PM   #11
Spencer
Drives: 2009 e90 335i Xdrive
Can you tell me more about this module? I am getting the same cornering light message, jumped the H3 bulb as mentioned in the posts, and found that one does not work. I plugged the working bulb into both sides of the car and I couldn't get it to light up. I tried the using the turn signal, and steering the car all the way both directions with the light on auto and then again with the lights in the on position, and nothing. Does that sound like a module problem?
