Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Replaced my faulty CIC, best option to get Nav working?
      09-10-2018, 01:30 AM   #1
Gee-Dog
Drives: E92 335i
Hi All,
I've read a thousand posts on different forums, and think I've worked out what I need.
I have a 2009 E92 335i, with CIC & Professional Maps, in Australia. My CIC has been playing up for a while - basically just restarts, runs for 30 seconds to several minutes, rinse & repeat. It doesn't do it all the time - it will work fine for months, then one day will start rebooting. It will do ythis for anything up to several days. The first time it happened, I replkaced the disk with a new mechanical one, and it seemed to fix it. A few months later it started again, so I replaced the new disk with an SSD - once again seemed to be ok for a while. It's now getting worse, and I'm convinced it isn't the disk. I pulled the CIC aprt a few weeks ago, and reseated the internal ribbon cables. It worked fine for 2 weeks after, but this morning started rebooting again.
I've bought a replacement CIC - it came out of a 2011 320D, with very similar options to mine, including Professional Nav. Today I put my SSD disk into the "new" CIC, and installed it in the car. Most things worked, but no Nav, no Bluetooth, and no oil level disply (might have been other things but thats all I noticed.
I connected my notebook, and used WinKFP to read the CAS, then wrote the VO back to the "new" CIC. The CIC powered off then on again, and now Bluetooth works, and I think the oil level will work as well. Nav says "Function currently not available". Everything I read tells me this is to be expected.
I'm after advice as to the best (read cheapest) way to get Nav working again. I believe I can buy an emulator - a hardware device that bypasses the FSC requirement. Is this my best option, and which one do I buy?
If I want to get an FSC code, where would I get this from? Is this a dealer thing? Would I need to supply my own Vasoline (do you even have Vasoline in the US - perhaps KY Gel)? Can anyone else get me an FSC code for NAV? I realise this is different ot the FSC code for updating maps - I have done that to my car previously.
What is Script Activation? Is this the same thing as getting an FSC code?
I've also read about a method of getting the FSC by a file on a USB, but it says this only works on US & EU market cars - mine is an AU model. Can anyone shed more light on this?
Any help is greatly appreciated.
      09-10-2018, 06:00 AM   #2
smass
398
Drives: 06 325i - 10 335i
2010 E90 335i  [0.00]
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
2006 E90 325i  [0.00]
https://www.bimmerfest.com/forums/sh...d.php?t=926082
or
http://bmwcoders.com/forum/bmw-codin...sc-codes-9913/
      09-12-2018, 10:07 PM   #3
Terraphantm
253
Drives: E46 M3 Coupe
Don't buy new FSC codes. You could use Intel123's CIC Patcher if you're not able to transfer your old FSCs.
      09-13-2018, 06:59 AM   #4
smass
398
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
That still requires the latest CIC flash right? And map updates seem like a pain afterwards.
      09-13-2018, 07:33 AM   #5
Gee-Dog
Drives: E92 335i
Isn't this the fix that only works on US & EU cars? Mine is Australian.
I have ordered an emulator, so will see how that works out when it arrives. Good news is that the replacement CIC seems to have fixed my restarting problem. Just need to get my maps back.
      09-13-2018, 12:37 PM   #6
Terraphantm
253
It would require the latest flash, yes. Map updates worked fine for me
      09-13-2018, 01:25 PM   #7
smass
398
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
Is there a good place to learn about script activation? I just need to buy the icom and do the update.
      09-22-2018, 06:03 PM   #8
Gee-Dog
Drives: E92 335i
For anyone doing a CIC swap in the future, I thought I'd post the latest update on my issue.
I received the emulator yesterday - a "plug & play" version with a plug & socket. I installed it, and after starting the engine my Nav changed from "option not available" to "enter code to start nav".
I used the USB method to get an updated 1b.hex file, then the FSC generator program to generate a new FSC code, entered this into the car, and now have working nav happy days.
The emulator was bought from China through Ali Express, and I bought the P&P vesion because I didn't want to cut & join wires. Cost was around $US40 shipped.
ace e0.00
      04-06-2024, 12:33 AM   #9
ace e
Drives: 2011 BMW 335i
Gee-Dog having the same nav issue, swapped the cic professional with the exact same model and unable to code the nav. Can you please message me the details of how the plug and play works?
      04-07-2024, 01:58 PM   #10
E92Danny
E92Danny's Avatar
14
Drives: 2010 E92 335i M-Sport
Same issue im having
2010 e92 Alpine white 335i
      04-08-2024, 05:08 PM   #11
BRG_N54
BRG_N54's Avatar
297
Drives: Green '07 & Arctic '08 335i's
2008 BMW 335i  [0.00]
2007 BMW 335i  [0.00]
First of all, you both realize that this thread is almost 6 years old, right? I would guess that many of the participants are no longer around.
Secondly, a quick google search for "bmw e90 cic emulator" turned up this, which is likely what the OP was talking about.
Getting NAV enabled on E9X CIC is kind of the secret sauce of these cars. Unless you want to roll up your sleeves and do it yourself, it may be wiser to find a reputable remote coder to do it for you.
