Login
09-06-2018, 06:33 PM | #1 |
Administrator
![]() 27798
Rep 20,449
Introducing the BMW X2 M35i
![]() Introducing the BMW X2 M35i ![]() 302 hp and 332 lb-ft. BMW’s most powerful 2.0L TwinPower Turbo Engine. September 6, 2018... Munich. Sportiness coupled with a polarising appearance – based on this formula, the new BMW X2 has inspired above all a young and modern target group following its premiere in March 2018. With its extroverted design, the BMW X2 interprets the character of a premium SAC (Sports Activity Coupes) in an entirely new way within the compact segment. The top-of-the-range version of the BMW X2 is the M Performance automobile. BMW is now presenting the new top model of the X2 series. The wide BMW double kidney grille of new BMW X2 M35i (combined fuel consumption 8.4-8.1 l/100 km; combined CO2 emissions: 191-185 g/km)*, features a surround in Cerium Grey for visual differentiation at first glance. Likewise, the surrounds of the air cooling inlets and the exterior mirror caps are finished in Cerium Grey. The rear of the X2 M35i is characterised by the standard M rear spoiler and two specially designed exhaust tailpipes, which also come in Cerium Grey. BMW’s most powerful 2-litre TwinPower Turbo engine. The new BMW X2 M35i featuring a 225 kW (306 hp) 4-cylinder turbocharged petrol engine definitely sets new benchmarks above the previous versions. As the letter M in the type designation clearly signalises, the new X2 M35i possesses the impressive dynamic handling qualities of an M Performance automobile. Behind this is yet again the BMW M GmbH, whose racing know-how flows into the development of all components. The 2-litre TwinPower Turbo engine concealed under an M Performance cover is the very first M Performance four-cylinder engine and at the same time BMW’s most powerful version. It delivers a fascinating maximum power output of 225 kW (306 hp). Maximum torque is an extremely powerful 450 Newton metres. To ensure that this sheer power is securely transferred to the tarmac, the X2 M35i comes as standard with intelligent four-wheel drive technology xDrive in conjunction with the 8-speed Steptronic transmission including Launch Control. The automatic transmission features specific M Performance tuning. Equipped in this way, the BMW X2 M35i is able to accelerate from 0 to 100 km/h in just 4.9 seconds*. The necessary thermal stability of the engine is now ensured by a redesigned cooling system. Outstanding driving dynamics thanks to M-specific tuning. Being a typical M Performance automobile, the BMW X2 M35i features, in addition to a powerful engine, also a M Sport suspension system that has been specifically tuned and adapted to match the car’s sporty character. A adaptive suspension offering two different manually adjustable modes and combining maximised sportiness and driving comfort is also optionally available. A particularly special technical highlight – and also a premiere for an M Performance automobile – is the M Sport Differential installed in the front axle gear. During highly dynamic driving manoeuvres, this locking differential most effectively reduces possible traction losses on the front wheels. In addition, the braking system has been upgraded for use on the X2 M35i. The M Sport braking system with fixed callipers in Dark Blue metallic and 18-inch steel discs at the front (17-inch at the rear) guarantees consistently short braking distances even under the highest loads. With that, however, the M know-how is still far from being exhausted. Steering and suspension have also both been adapted to match the performance of the drive system. For instance, thanks to a special setup, the M sports steering conveys to the driver an impressively direct and precise steering feel. Furthermore, the X2 M35i comes as standard with the M Sport suspension with a stiffer spring and damper setting as well as vehicle lowering. The rear axle construction has been redesigned. A suspension with an adaptive spring and damper combination offering two different manually adjustable modes is also optionally available. Upgraded exterior design thanks to M Performance typical elements in Cerium Crey. The sporty aspiration of the X2 M35i, which is the result of its inner qualities, is reflected in an exciting exterior design with numerous typical M Performance Automobile elements finished in Cerium Grey and based on the X2 M Sport Package. This begins at the front with full HD technology for the main headlights and fog lights and continues with the double kidney grille in Cerium Grey and the newly designed side air intakes of the same colour at the front for best possible cooling of brakes and engine. The exterior mirrors have been upgraded by special caps, likewise in Cerium Grey. At the rear, the X2 M35i boasts a distinctive M rear spoiler and demonstrates its fascinating sovereignty with an M Sport exhaust system with two tailpipes (each 100 mm in diameter). Thanks to the adapted silencer system, the exhaust system produces a particularly sporty sound spectrum. 19-inch M Sport light alloy wheels in 715M styling (optional: 20-inch M Sport light alloy wheels in 721M styling and in Cerium Grey bicolour) impressively round off the exterior design features. For the first time Exclusive M sports seats ensure perfect seating comfort and lateral support. An exceptionally sporty look also dominates the interior. As with the exterior design, the basis is again the M Sport Package. Moreover, the X2 M35i features as standard an M Sport leather steering wheel with shift paddles and door entry trims at the front bearing the lettering “M35i”. The optional M sports seats at the front are a novelty. They offer not only perfect lateral support for both driver and front passenger in sharp bends, but also the highest level of comfort and safety through integrated headrests. The M sports seats are available in the following three different designs: FabricTrigon/Alcantara combination in black with blue accents, Leather Dakota Magmared, perforated with black accents and Leather Dakota black perforated. Matching seatbelts in an M design are also on offer. Trend-setting digital competence for state-of-the-art technologies. In addition to the uncompromisingly sporty orientation of both drive system and design, the BMW X2 M35i also demonstrates BMW’s trend-setting digital competence in the areas of operation and networking. For instance, the full-colour BMW Head-Up Display is among the optionally available features. It offers a display range that is unprecedented in this vehicle segment. If desired, the latest generation of BMW ConnectedDrive and the new BMW Connected App can be fitted. Optional functions such as the wireless use of Apple CarPlay set further highlights. Driver assistant systems include, for example, camera-based technologies such as the traffic jam assistant for less tiring driving in dense stop-and-go traffic or the optional parking assistant. Start of production is November 2018, for European markets not until March 2019.
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook Follow us on Bimmerpost Twitter Subscribe to Bimmerpost Youtube Channel |
09-06-2018, 06:42 PM | #2 |
![]() ![]() 1629
Rep 1,260
Drives: M2 CS
Nice!!
2020 BMW M2 CS DCT (MB)
2018 BMW M3 DCT ZCP (AY/FBL) - sold 2015 BMW M3 DCT (AW/FSO) - sold 2011 BMW M3 Coupe 6MT ZCP (MW/BL) - sold 2007 BMW M Coupe (IB/BL) - sold INSTA: hedoniste__ |
09-06-2018, 06:47 PM | #4 |
![]() ![]() 2221
Rep 3,634
Wow. This is seriously cool
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
Jsinghzzzz75.00 |
09-06-2018, 06:47 PM | #5 |
BMW Client Advisor
3173
Rep 2,505
Drives: 2020 M340i
Yes please!!!!
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. ![]() |
09-06-2018, 06:49 PM | #6 |
Rep 9
this is so disappointing to me. I wanted to get an X1 with the 3.0l n55 but they only offered that car with the 6 speed auto, I wanted the 8 speed zf, my hope was the x2 35i would have the 3.0l with a zf8 and they downsized it to a 2.0l
hoyasaxa514.50 |
09-06-2018, 06:49 PM | #7 |
BMW In My Veins
![]() 41
Rep 13
Those seats though
Saphirschwarz831.50 |
09-06-2018, 06:51 PM | #8 |
Blocked from G80/G82 for having an opinion
![]() 9234
Rep 4,799
Love the red seats! They look like the ones from the Z4. Hopefully BMW starts doing this in new cars like the upcoming M340i.
Daily: 2019 Mercedes-Benz CLS 53 Weekend: 2008 BMW Z4 M Wife's: 2020 Mercedes-Benz GLC 300
Retired:1995 E36 325i 5MT / 2004 E46 330i 6MT / 2011 E90 335xi / 2017 G30 540i / 2017 982 Boxster S 6MT / 2019 F87 M2C 6MT |
ishowerinjager101.00 |
09-06-2018, 06:53 PM | #10 |
![]() ![]() 2636
Rep 7,877
You get an ///M Model!
And you get an ///M Model! Everyone gets an ///M Model!!!
19
BimmerMat135462.00 BMWZ41106.50 Quattr0960.50 drexplode1121.00 dmboone254601.50 TheUltimateDrivingManiac618.00 pyrat15142.00 DrifterX477.00 ///Cardia295.50 Smooth 330i922.00 8_is_enough188.00 JustChris12175.50 ///M4ster Yoda4551.50 6ixSpd5675.50 krautmeister127.00 Eddien1231426.50 Sefano3252.00 hoyasaxa514.50 963mw285.00 |
09-06-2018, 06:54 PM | #12 |
![]() ![]() 2197
Rep 2,635
Drives: G06/G20/F30/F15/F10/E90
The seats are really cool
09-06-2018, 07:05 PM | #18 |
BMW Client Advisor
3173
Rep 2,505
Drives: 2020 M340i
09-06-2018, 07:05 PM | #19 |
Do it for a living.
51
Rep 133
Blubaron791187.50 |
09-06-2018, 07:09 PM | #21 |
![]() 1229
Rep 3,006
09-06-2018, 07:10 PM | #22 | |
![]() ![]() ![]() 3707
Rep 8,662
Drives: Smog machines
Have to say that this drivetrain is actually kind of appealing compared to a one wheel drive non M rwd setup or regular X Drive. My DD GTI with a mechanical LSD is actually surprisingly fun, add some power xfer to the rear and it could be quite good. The Golf R foolishly doesn't keep the mechanical front LSD. |
