Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > New to NCS expert, having issues reading modules
      08-28-2018, 01:36 PM   #1
Dr.Rockso
Drives: 2007 335i, 2011 335d
I have NCS expert setup correctly I think, but I am having issues reading my NFRM module. I have a 2011 335D, and recently downloaded NCS expert from bimmergeeks. Are there any updates I need to do to the software? Unfortunately the error messages are in German so I don't know what they are saying.
Trying a simple coding job of turning up voltage on my angel eye bulbs.
Thank you for the help, this whole process has been a bit frusterating
      08-28-2018, 01:54 PM   #2
Dr.Rockso
I keep getting this error message in log:
[11: 52: 22.065] [2018-08-28] [SERIES] 2021 Error LFCDHDIA.CPP (A_PL2FRX.IPS / IPO) CDHapiResultText 1
[11: 52: 22.065] [2018-08-28] [SERIES] Data transfer to SG disrupted IFH-0010: Data transfer interface / control unit faulty FRM_70
[11: 52: 22.185] [2018-08-28] [SERIES] 2021 Error COAPI2.CPP coapiRunCabd 6
[11: 52: 22.185] [2018-08-28] [SERIES] Data transfer to SG interfered with CODE_DATA_READ
      08-28-2018, 11:39 PM   #3
Doesha
30
Drives: 2006 330i Pre-LCI Monaco Blue
Do you get both circles black in inpa? Make sure all your modules are reading in inpa and not showing an error. Did you set up the profile correctly in NCS and not just use expertmode. Make sure your on com1 for your serial USB in device manager and latency set to 1
      08-28-2018, 11:40 PM   #4
Dr.Rockso
Looks like I need to update my NCs expert files. Anyone have a link to v55 of them?
      08-28-2018, 11:45 PM   #5
Doesha
30
They are at like version 65
Last page on date. Request has this link. Just downloaded it today and use coding took to update everything.
https://mega.nz/#F!p5gV2KAA!dJm9MjM9d95hnvo-wygMZA
Just know if you just downloaded standard tools from bimmergeeks the daten files should be most uptodate
Link is credit from joe@topgearsolutions
      08-29-2018, 08:46 AM   #6
Dr.Rockso
Thank you Doesha , I downloaded them a while ago but just started trying to mess with them. I may have gotten a corrupted download or who knows. I really appreciate the link
      08-30-2018, 12:58 AM   #7
Doesha
30
Yes the link is quite finicky. I tried downloading it at my work using chrome and edge wouldn't go for whatever reason. Went to my mom's house and used chrome downloaded just fine in 10 to 15 mins. I tried like 3 times then got it. I will see if I can upload it to my Google drive and pm you the link when I go to work tomorrow
      08-30-2018, 02:22 PM   #8
Dr.Rockso
Well downloaded the update and applied it, still not working. Now it gives me a weird german error message but nothing stored in logs. Looks like the same message about the cable. I have it set to com1 and the switch on the cable set to the right. The cable seemed to work when I tested it with xHP flash, but didnt do anything other then see if it connected to the vehicle i read vehicle information.
      08-30-2018, 03:11 PM   #9
Doesha
30
is latency set to 1 or 16 still?
      09-01-2018, 06:24 AM   #10
Dr.Rockso
Set to 1. I figured out the problem..kinda. either my cable is defective, or there is something wrong with my obd2 port. The cable is really hard to fit in my port, and if I hold it in the right position I can successfully download and upload to my nfrm. BTW coding my DRL didn't really work because my LED bulbs I replaced in there don't change intensity with voltage. **Facepalm**. But I know the coding process now.
      09-01-2018, 11:16 AM   #11
Doesha
30
LZLRUN INPA K+CAN K+DCAN Car Diagnostic Tool Cable OBD USB Interface for BMW R56 E87 E93 E70 https://www.amazon.com/dp/B017IG81SQ..._wxFvqk3eeuDGk
This one works perfect
