BMW Carly App Codes.. please Help
08-25-2018, 05:16 PM | #1 |
Rep 5
Hello, My car is a 2006 E90 352i and unfortunately stuck in limp mode and stuck in park. The fault codes I have from Carly APP read as follow:
1- Fault Code 00CD99 2- Fault Code 00CD9E 3- Fault Code 00CD9D 4- Fault Code 00CDB0 Does anyone know what they may mean or help point me in the right direction? Thank you, -Dan |
08-27-2018, 11:57 AM | #2 | |
263
Rep 1,173
09-05-2018, 07:14 PM | #3 |
Rep 5
Thanks for responding! so far no issues with leaking.. I've replaced the crank shaft position sensor and the intake Cam Shaft sensor. I've also cleaned both the Vanos intake and exhaust sensor. I'm still in the process of trying to find out what the Fault Codes mean. I will post here once It's back running strong again. Any other recommendations are appreciated. Thanks!
09-06-2018, 12:00 AM | #4 | |
626
Rep 2,099
That usually gives you more info. Ain't full BMW scantool instructions but gives you a basic diagnostic each time. example: or does it happen to be like one of these? But this does at least give you a part. I think many of these are usually google-able if you remove the 00. |
