BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > NCS Expert Error in CABD COAPI: 2041
      08-17-2018, 12:44 PM   #1
TheGoodTheBadTheUgly
257
Drives: 2011 E90 335i xDrive
Hey guys, I own a 2011 BMW 335xi N55 E90.
Today I tried replacing my 90ah battery to a 70ah using a guide on this link.
https://www.e90post.com/forums/showthread.php?t=1338302
I was following Option 5, (Method where I change vehicle order through NCS Expert) but when I hit "F1 (Code Car) I've got an error message from NCS expert an it said that the coding failed (This was at the second Step 7 from the Option 5) of the above link).
Here is the error code:
Error in CABD! Look at CABI.ERR and ERROR.LOG!
COAPI-2041: Falscher SG-Cidierindex A_PL2FRX: CODIERINDEX = 33h
FRM2_E89.C08: CODIERINDEX = 8
COAPI-2041: Falscher SG-Codierindex CODIERDATEN_LESEN
I tried on two computers, one with Windows 7 64-Bit and the other Winows 10 64-Bit. Both of them had the same error. I was using the BimmerGeeks Pro K+Dcan cable and had drivers installed for USB converted as well as my COM Port setup to #1 with a latency of 1.
I ended up doing Option 4 so I got my battery to work. I just want to figure out why it is not working for future coding I might do.
Thanks a lot ladds!
      08-17-2018, 05:50 PM   #2
LMB335IS
Sua Sponte
LMB335IS's Avatar
1299
Drives: 2013 LMB 335is
2013 BMW 335is  [8.84]
The first thing I see wrong in both procedures in option 5 is that you should be using factory coding profile WITHOUT manipulation. With the bimmergeeks software it would be the factory coding profile. Did you go back after changing the VO and verify that the VO did change?
335is/DCT-M3 GTS software-M3 drivetrain-M3 GWS-KOMBI-DSC-SZL/MHD/BQ Tuning IG@ClustersandCoding
      08-18-2018, 01:41 PM   #3
257
Hmmm ok, that is weird because in the posts it says to use a profile that has manipulation enabled.
Anyways, yes I did manage to do Step 1 to 20 and change my VO. I changed the -B090 for the battery to -B070. I went back and checked if it saved and it successfully did.
The only part that did not work was really the last step of Option 5 which was "Code Car".
Other than the profile that I was using was the one provided with the software, the "Dummy Profile".
      08-19-2018, 12:04 PM   #4
LMB335IS
Sua Sponte
LMB335IS's Avatar
1299
Check both your profiles. Load a profile then go back and pick edit profile. Click through the password and click the FSW/PSW button and see if the FSW/PSW manipulation box is checked. You want to have one profile with it checked and one without. The profile that's checked is used for making actual changes, the unchecked one if used for default coding which is what you want to do after you change the VO. Default coding codes the car based on the VO back to factory specs which is what you're trying to do to apply the changes based on the new VO you have.
While you're in the edit screen of your profiles you can change the name of it to whatever you want so you'll know exactly what the profile will be used for.
      08-19-2018, 06:14 PM   #5
257
Ok I am pretty sure that might be it. I will try it and tell you what happens. It's just odd that they told me to load a profile that had manupulations enabled for the second part.
Anyways thanks for all!
      08-19-2018, 06:21 PM   #6
LucasAry
Drives: BMW 3 Series (E90
+1
      08-19-2018, 07:15 PM   #7
LMB335IS
Sua Sponte
LMB335IS's Avatar
1299
That's because that post is wrong and no one's ever corrected it. Not to mention the coding procedures in step 4 are archaic. There's much quicker and easier ways to code using either NCS Dummy or the BMW Coding Tool.
      08-19-2018, 08:01 PM   #8
257
I see haha I ended up doing the Option 4 because it was the only one that I could make work. Should I still modify the VO order and code it like in option 5 or option 4 was enough?
      08-19-2018, 08:10 PM   #9
LMB335IS
Sua Sponte
LMB335IS's Avatar
1299
I see haha I ended up doing the Option 4 because it was the only one that I could make work. Should I still modify the VO order and cose it like in option 5 or option 4 was enough
Option 4 works. Just be mindful that if the car is ever updated or has a module replaced, especially by the dealership, that the coding will be erased when they do a blanket update. Other than that you should never have a issue.
      08-19-2018, 08:31 PM   #10
257
Great thanks for everything. I really appreciate it!
      07-07-2021, 11:13 AM   #11
bmw-extreme
Drives: e90
I have the same problem. (Same error message) Frm cannot be read and coded in ncs (Both sg codieren and codierdaten lesen don't work) But it works when writing FA into frm. I may succesfully write FA into frm. I noticed something. Frm cannot be coded with Autologic either. I am able to reset the frm with Autologic, but not code. Both smcs are broken. Could this be why the frm can't be read and coded?
      07-08-2021, 04:09 AM   #12
bmw-extreme
Drives: e90
Update.
Problem is solved. Maybe that helps someone. Well you may get that error if your car has a frm, and you have updated your car's build date to #0909 to code the cic. In my issue, that was exactly so. Ncs wanted to see ancient frm as frm2_c08 and didn't code it. When I again coded factory build date in VO, ncs has seen the frm and i managed to read it.
      12-14-2021, 10:16 PM   #13
jagster936
Drives: 2010 BMW 335D
I wonder if I have related problem, FRM coding. See my link here:
https://www.e90post.com/forums/showthread.php?t=1883351
