Is the idler pulley suppose to be tight? Hard to spin?
08-15-2018, 11:04 AM | #1 |
Crazy Frog
543
Rep 1,211
I just changed my belt, belt tensioner, and idler pulley on my 11' 328.
Everything went smoothly but I noticed that the new idler pulley seems too tight to spin freely. The old idler pulley spins freely while bolted to engine. The new idler pulley seems extremely tight when it's bolted to the engine. It definitely will not spin freely. The new idler pulley doesn't seem defective, it spins freely in my hand but once i bolt it to the engine it doesn't spin free. Do new idler pulleys need to be "broken in"?
08-15-2018, 11:51 AM | #2 |
183
Rep 1,082
I replaced my pulleys and tensioners and the old and new ones spun with same resistance which made me regret replacing them
It takes a big man to cry. It takes an even bigger man to laugh at him-- Jack Handey mods: blackout grill, finishing rods, badges, Blacklines. |
BimmerNugget542.50 |
08-15-2018, 12:33 PM | #3 |
708
Rep 2,606
Drives: 06 330i E90, 18 530xe G30
Did you over torque the bolt that holds it down? I had the same experience with Bamaben, when I proactively did my belt. The new one did feel smoother, but spun with a very similar resistance. Sounds like something went wrong, I'd try and check to see if backing off the bolt helps first.
08-15-2018, 12:39 PM | #4 |
Crazy Frog
543
Rep 1,211
Thanks, I will try backing off the bolt
08-15-2018, 01:44 PM | #5 |
187
Rep 589
This may sound dumb, but make sure the pulley isn't on backwards. It will bolt up backwards and seem like it's on correctly but won't spin freely
08-15-2018, 02:22 PM | #6 |
Crazy Frog
543
Rep 1,211
Shit...let me check. I just kept the metal circle plate on the same side as it came
08-15-2018, 07:18 PM | #8 | |
General
17364
Rep 18,756
08-15-2018, 07:20 PM | #9 | |
Crazy Frog
543
Rep 1,211
It's the idler pulley thats the problem. It's extremely hard to spin it. But it spins fine when not bolted to engine. I went out for 30 minute (8 mile drive) then shut the car off to check the belt. The belt feels really hot. I can only place my finger on it for 3 seconds max before becoming unbearable. Is it normal for the belt to get that hot? I'm starting to think that idler pulley is causing issues.
08-15-2018, 07:23 PM | #10 | |
General
17364
Rep 18,756
