WANTED E90 N53 intermediate exhaust section
08-13-2018, 08:20 PM | #1 |
209
Rep 461
Looking for a N53 intermediate Exhaust section, so I can cut out the NOX cat..
This is the part from the primary headers to the back back connection and has the secondary cats and Nox cat. As I am going to remove the NOX cat it would be fine if it has knackered NOX cat... |
08-14-2018, 07:00 AM | #2 |
36
Rep 278
I thought the secondary cats (boxes next to the gearbox) were the Nox cats anyway?
The Nox sensor is after these secondary (Nox) cats. The box near the diff is a resonator unless I'm mistaken? |
08-15-2018, 06:26 AM | #5 | |
616
Rep 3,194
Drives: E92 325i MSport Coupe
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
08-15-2018, 06:49 AM | #6 |
36
Rep 278
Ah okay so the box at the back is actually a Nox cat? I thought it was those round ones near number 6 on the diagram lol!
Good job I haven't removed any of them then as I really want to keep the resonators to minimize drone. |
08-15-2018, 09:21 PM | #9 | |
209
Rep 461
Number 16 - is the resonator after the resonatir you have the over axle pipe to the back box. Number 6 - are the secondary cats which have NOX function. I’m pretty sure it’s this way round as the NOX sensor is before the resonator and temperature sensure is before the cats I’ll be removing the cats at number 6. Im questioning whether to gut them or replace with straight pipes I think straight pipes will be better.. |
