The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Active Steering
      08-05-2018, 03:54 PM   #1
dreyo27
92
Drives: 2007 335i e92
Active Steering
Has anyone been able to code out Active Steering?
My 2007 e92 335I has it and I can't install VTT Shotgun Kit becasuse of it. I would love to just replace it with an M3 steering rack and be done with it. I just don't want to have a bunch of lights on after I remove it.
      08-05-2018, 07:55 PM   #2
Impac
21
Drives: Bmw
I have on a e92 and e60 its little tricky, you have to remove the a/s vo and code default KOMBI, SZL, SGM, that should be enough, remove a/s fuse/module, than in order to get the DSC error light out you need to flash DSC with NON A/S zb# winkfp EXPERTMODE !!!
      08-09-2018, 03:46 PM   #3
dreyo27
92
what is this "a/s vo" I do have winkfp on my laptop. going to give it a try.
also to "flash DSC with NON A/S zb" does that mean I have to find another car and back it up and flash it onto mine?
really appreciate your help Impac
      08-09-2018, 04:51 PM   #4
Impac
21
Drives: Bmw
A/S Active Steering, VO Vehicle Order
1)Removed Active Steering Fuse in GloveBox or Module
2) Remove $217 from VO/FA and coded default KOMBI, SGM, SZL, this should clear the error if error is still there manually read KOMBI and set any AFS string to Nicht_Active
3) Than if you have DSC dash light AND YOU WILL lol, use WINKFP to flash EXPERT MODE use google for PDF
(BMW winkFp ExpertMode)
You can use RealOem to figure out the zb# or find someone without
$217 Active Steering or $216 Servotronic and use their DSC zb#
4) Than Just perform Steering Angle Calibration ista d or Tool32 and all good to good
      04-01-2020, 09:11 PM   #5
SG_E90
DaZuc
72
Drives: S65 1M Clone
Some useful info for
335xi DSC ZB w.o AFS.
6783295
335i DSC ZB w.o AFS.
DSC_87
6776067
These may not be w/ latest update.
      09-21-2021, 03:16 PM   #6
kombinator-318
Drives: 325d
Dear Forum,
for a special project I need to get my DSC MK60E5 flashed with NON-ACTIVE Steering Software. I have read all details here in this thread I have used EXPERT Mode to flash it with the ZUSB 6776067. Sadly I get an error 211. with the detail (see attached screenshot and errorlog)
When flashing back with the original ZUSB 6791524 I can make it work again.
This is the current AIF:
Einträge des Anwenderinfofelds:
Eintrag 1:
Fahrgestellnummer: P193837
Datum: 29.03.2008
Änderungsindex: 00
Softwarenummer:
Behördennummer:
Zusammenbaunummer: 6784766
Seriennummer:
Programmstand:
Kilometer: 0
Händlernummer:
Eintrag 2:
Datum: 20.09.2021
Änderungsindex: 00
Softwarenummer:
Behördennummer:
Zusammenbaunummer: 6791524
Seriennummer:
Programmstand:
Kilometer: 0
Händlernummer:
File Type: txt Fehler PAD aktiv.txt (49 Bytes, 60 views)
      09-21-2021, 03:20 PM   #7
kombinator-318
Drives: 325d
Sorry for the simple question, how do you figure out the zb# from realoem ?
That is the DSC90.DAT file will latest ZUSB numbers:
It is clear that non AS and AS DSC has different HW number.
$ PS10INIT N00000000000000000000000020000000000000 D
$ VERSIONKFCONF: kfconf10.dat
;Zusbauvorschrift vom 21.08.2012 09:55
;SG-TYP: DSC90
;ZB-NR TYP-NR HW-NR IX SW-NR AM PIN S CS
4029563,0000000,4029563,A,0000000DA,0FFFFFFFFFD,00 0,1 Y
6776067,0000000,6776067,A,0000000DA,0FFFFFFFFFD,00 0,1 6
6776069,0000000,6776067,A,0000000DA,0FFFFFFFFFD,00 0,1 C
6775389,0000000,6775387,A,0000000DA,0FFFFFFFFFD,00 0,1 W
6791524,0000000,6791524,A,0000000DA,0FFFFFFFFFD,00 0,1 C
6862873,0000000,6862873,A,0000000DA,0FFFFFFFFFD,00 0,1 K
6775387,0000000,6775387,A,0000000DA,0FFFFFFFFFD,00 0,1 Q
