Battery and Engine light
08-02-2018, 02:03 AM | #1 |
Rep 21
Hi guys! how are you all? i have a couple things to discuss.
i recently washed my engine bay (stupid thing to do) i just used the regular hose we have at our house. no pressure just normal, after i was done the engine light came on, i didnt notice anything with the cars performance though, it was fine, then it went away in a couple hours. its been a few weeks now, and ocassionally , the light randomly comes on and goes away in a couple hours, this never happened before with me, is something wrong with the car? i dont know what to do, but i never notice anything in driving the car, its just the light, and second, im thinking of getting a battery for the car and i dont wanna pay 600$ for it if i get from Bmw , can i just get one from Canadian tire or Costco for way less (150-200$) would that battery work the same? oh and btw the car is a 323i 2009 Thank you everyone! |
08-02-2018, 02:44 AM | #2 |
145
Rep 334
First of all.... never a good idea to wash your engine Bay!!!! Especially with a full blown hose. Never do that again... As you know as complex as these cars can be there are a lot of sensors working together to constantly give information to the ECU. Good chance you got a sensor wet. I would go though all of the connections that are visible and one by one clean and reconnect each one. Keep in mind you want to disconnect your battery before you do so.
My Indy mechanic always tells me to leave battery disconnected for at least an hour because the car still may have some juice in it. 2. Your battery can be replaced by the one at Costco that's fine. You'll have to register your battery with the car as well. You can get a local Indy mechanic to do that or you can use the Carly app.(you'll need the Carly adapter)
JP
Zainrz963.00 |
08-02-2018, 10:12 AM | #4 |
1044
Rep 1,667
I washed mine a few weeks back because I had a coolant leak and got antifreeze all over the place. I covered the obvious electrical connections and alternator with foil. I sprayed degreaser on the engine and I used a low pressure hose and minimal water (just to wash off the degreaser). After I was done I ran the engine to try and dry off any water that was pooled on the engine.
I don’t know that this will keep you from having issues but it worked for me... |
Zainrz963.00 |
08-02-2018, 12:31 PM | #5 | |
206
Rep 349
I also think there is no good reason to wash an engine bay. wipe off dust with shop paper towel. If there Oil you need to find the leaking source and fix it. |
Zainrz963.00 |
08-03-2018, 11:13 AM | #10 |
392
Rep 2,367
Drives: 2011 335i
08-03-2018, 11:16 AM | #11 |
719
Rep 1,753
08-03-2018, 12:05 PM | #12 |
Art Collector
2427
Rep 3,450
I've also done it a number of times before... Never had any issues.
I think the key here is to not pressure wash the living shit out of it, lest you end up forcing water past seals on electrical connectors, or into other nooks and crannies that shouldn't be getting wet. Apparently it's good practice to cover your alternator, and perhaps a few other areas, but I've never bothered. And if you live where I do (freezing 8 months of the year), then it's probbbably not a good idea to do it if it'll freeze before it dries. ------------ LOL just noticed OP lives where I do too. Whattup. |
Zainrz963.00 |
10-16-2018, 04:27 PM | #13 | |
Rep 21
Hey, really sorry for the late reply, just came on here and saw this What part of Calgary are you in? |
