07-26-2018, 11:55 AM | #1 |
15
Rep 17
CarPlay for NBT (or NBT to EVO upgrade)
Hi guys,
I know this has been discussed a million times on here, and I have found varying levels of info on this topic, so thought I would post a new topic and see where this winds up. Have a 2014 435i (F32). My understanding is that this comes with NBT. My objective was to figure out how I could get CarPlay on it. My understanding is that in order to get CarPlay, plus the updated tile menu, one would require NBT-EVO. I also read of various ID versions 4++, 5, 5++, 6 light, 6. I am not sure what version I would require for CarPlay to be installed/working. So to my question, is there any way, without ripping out dashboards, headunits, hardware, that I can simply flash or code from NBT to NBT-EVO. And if I remained on NBT (non EVO), can I upgrade from current ID version (assuming 4++) to 5 or 6 ?? Again, objective is to add CarPlay to current NBT system. Now, before anyone jumps to the answer no not possible, I found this link below that claims it is possible for NMT 2012-2016 models. http://www.naviplus.com.au/single-po...m-2012-to-2016 Thanks Neil |
07-26-2018, 12:02 PM | #2 |
Rep 29
The way they achieve CarPlay if I am not mistaken is by adding a "CarPlay box" that connects to your existing NBT unit and uses a separate microphone, at least for the one I have seen.
Having the NBT Evo would be the only way to ever have the real BMW CarPlay. NBT and NBT Evo are completely different hardware too so there is no way to upgrade software to achieve this with your current set up. |
07-26-2018, 01:08 PM | #3 |
620
Rep 2,013
If you decide to upgrade your iDrive to NBT Evo ID5/6 our retrofit kit comes with CarPlay activated.
If you don’t want to change the whole iDrive system, contact us to add CarPlay MMI to your existing iDrive |
07-26-2018, 03:14 PM | #4 |
15
Rep 17
To Bimmertech,
From what I read on your site, it seems that a swap of the head unit is still necessary to add any sort of CarPlay module. I would like to avoid opening up the dashboard, and ideally if I have to, simply plugging in an external module somewhere, whether it be via USB or a harness in the trunk. My guess is that one will have to get behind the dash and head unit to be able to connect this unit of yours to some stock harness back there, correct ? As for the EVO upgrade, what does that involve, a complete swapout of the head unit and display ?? Any other hardware changes ?? Any mods required to the dash for display or headunit ? Thanks |
07-26-2018, 04:32 PM | #5 | |
620
Rep 2,013
https://www.bimmer-tech.net/shop/bmw-3-series-f30-f31-f34-f80/connecteddrive-retrofits/carplay-activation And click “Check compatibility with your BMW”. Enter your VIN and see if we can do a software activation or CarPlay MMI or nothing at all. It will even tell you if you need a WiFi antenna for the activation. Since you have NBT, the software activation won’t be compatible. If you have any other specific questions drop us an email with your VIN to info@bimmer-tech.net and we will be happy to help. |
07-28-2018, 08:26 AM | #6 |
BimmerPost Supporting Vendor
665
Rep 1,976
Drives: 2020 G20 320i M Sport
We do have a new CarPlay interface available that supports iOS screen mirroring as well.
You will need NBT for this to work. This kit also uses your factory mic so there is no need to run an additional one. It is however wired and not wireless.
CMB Solutions Limited |codemybimmer.ca
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs Last edited by steve@codemybimmer; 07-28-2018 at 08:58 AM.. |
x-m4n148.00 |
07-31-2018, 06:59 AM | #8 |
148
Rep 766
Thanks for the video, a couple of questions. Is there a way to connect the phone and jump directly to carplay mode? Could you go full screen there without the carplay logo at the right?
01-29-2019, 11:22 PM | #9 |
28
Rep 211
sorry to bump an old post... i'm looking into updating my NBT system to the new style. I currently have a 2014 750i with NBT_O16255A
What can I do to get the newest NBT? I've seen some Russian videos that claim to be able to code/update the NBT system with the new EVO software without having to change out the hardware. Worst case, if I do have to change the hardware, what do I need? Just a new screen and NBT module? |
02-04-2019, 10:04 AM | #10 | |
14
Rep 81
I bought mine from ebay. NBT evo. better than flashing an id4 to id5. its buggy and there is a chance that it will random reboot. just pay the money and get a ID5/6 unit. worth every penny. Kamal |
02-06-2019, 01:32 PM | #11 |
Rep 27
Did you do your own coding to get everything working with your new ID5/ID6 unit? I would like to go the route of buying my own NBT_EVO ID6 unit, but don't have clear guidance on the coding aspect to have everything work with my VIN.
02-06-2019, 11:52 PM | #12 | |
14
Rep 81
Steve@codemybimmer coded it for me. Activated carplay. Write VIN and activate nav and vim with fsc. That again, worth every penny. Within an hour he had everything coded and running |
steve@codemybimmer664.50 ricobrumsey0.00 |
05-09-2019, 07:10 AM | #13 | |
10
Rep 138
Connected drive also? Sirius radio? |
05-10-2019, 08:28 AM | #14 | |
665
Rep 1,976
We even support South East Asia and Australia now.
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
05-14-2019, 01:21 AM | #15 | ||
14
Rep 81
08-02-2019, 03:33 AM | #16 | |
Rep 19
08-03-2019, 01:46 AM | #17 |
Rep 1
BimmerTech Carplay
Hi All,
I have a 2016 F33 (with NBT) that unfortunately didn’t come with CarPlay or the later version combox. My work-around was to purchase BimmerTech’s CarPlay box. Overall happy with the unit as I now have iPhone apps- Waze/google maps/Spotify to name a few. For anyone else with the BimmerTech CarPlay unit, hoping you can help with a few things.. Since installing, I can no longer see service requirements in the iDrive (can see service history still) Annoying as I can’t see things like when take pads are due, etc. anyone else note this ? Other things include : -HUD directions no longer show (confirmed by BimmerTech that is doesn’t support - after I purchased the unit) - can’t adjust time or date (for daylight savings) - can’t select a few options in the trip menu settings Anyone else experience this, or is it just my unit ? Cheers, James |
08-04-2019, 06:46 AM | #18 |
Rep 31
Good reviews on the unit linked below for fullscreen wireless carplay & Android Auto.
Tempted to pull the trigger on this and ditch my Android screen and go back to my NBT 8.8 screen. https://www.aliexpress.com/item/3300...32e43c00GoLqTL |
sbinshihon684.50 |
08-05-2019, 05:40 PM | #19 | |
Z4 35is
59
Rep 270
2011 Z4 E89 35is 2016 435i GC m-sport
08-14-2019, 07:50 AM | #20 |
Rep 22
01-25-2022, 07:31 AM | #21 | |
Rep 1
Which eBay seller did you buy from? I’m looking to do the same with my BMW X5 F15 2014. It has the NBT unit in it and want to upgrade to NBT EVO ID6 Professional. Any hep would be much appreciated. Cheers David |
