07-16-2018, 09:00 AM | #1 |
231
Rep 206
[M40i owners] Do you have any steering wheel vibration at 50-55 MPH?
I've been dealing with a vibration in my M40i (delivered in April) that started just after 4000 miles. The vibration is most pronounced between 50-55 MPH while under light load (i.e. maintaining speed). The dealership had it for 2 weeks and tried various things including wheel balance and driveshaft balance with no improvement. The regional rep was brought in and drove the car deciding he wanted to drive another M40i to compare. As yet, he has not found another to drive and asked the dealership to give me my car back saying he believes it is just a characteristic of the car. I refuse to accept that answer as the car was smooth as glass prior to around 4000 miles and I don't believe this is acceptable for a $68K vehicle. The vibration is enough that my hand gets numb after just a few minutes at speed.
So I'm reaching out to the community to see if anyone else has any similar vibration. |
07-16-2018, 11:52 AM | #2 |
185
Rep 298
What kind of wheel/tire combination do you have? Did they perform a road force balance? It sounds extremely lazy that the rep would say it's just a characteristic of the car. They should try swapping the wheels with another X3.
07-16-2018, 11:53 AM | #3 | |
231
Rep 206
I'm disheartened that the rep would claim it's a characteristic. I fear this is going to make it a real challenge for me to get the issue corrected. |
07-16-2018, 12:24 PM | #4 |
185
Rep 298
Yeah, that's unacceptable. The dealership may or may not have a road force balancer, and I would confirm with them whether they used one. It can make a significant difference over a regular balance, and supposedly low profile tires like the 21" ones we have are more susceptible to balance issues.
You could also go to an independent shop that has a road force balancer and have them check the front wheels. |
07-16-2018, 01:14 PM | #5 | |
231
Rep 206
07-17-2018, 12:24 AM | #6 |
626
Rep 1,044
Drives: 2018 X3 M40i, 2012 X3 Xdrive35
The dealer had it for two weeks. Let them have it for another week and initiate a dealer buyback. In California, it's 30 days. If it's that bad, you don't want it.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
07-23-2018, 08:05 PM | #7 |
16
Rep 12
I have the exact same issue. x3 M40i - picked it up end of February. I did some experimenting today and discovered a few things.
1. It doesn't seem to matter what type of wheel. I have 19" with All-Seasons. 2. I also get the high frequency vibration between 50-55 MPH but if you come off the gas, the vibration goes away. It's only when maintaining speed and lightly giving gas. 3. I set the cruise control at 52 MPH and switched to Sport. The RPM's went to about 2k, vibration was still there but not as bad due to the change in engine pitch. 4. It seems to be a combination of two things, the hard side walls of the RFT's in resonance with the engine note. In D at 50-55, RPMs are between 1250 and 1500 with the vibration. If you either coast (no throttle) or be at any other speed, there is no high frequency vibration. Even in Sport with engine RPMs at about 2K and 50-55MPH, there is vibration but not as bad as when in Drive. 5. I recall this started happening very early on as well. I really think if you put non RFT's the issue will go away. The hard side walls translated road vibration. Keep us posted and I will do the same! |
11-03-2018, 04:59 PM | #8 |
82
Rep 432
Bumping this thread.
This is extremely relevant to many of us experiencing this issue. Shocked that there has been no response to this thread since July; hoping that means you found a solution. |
11-03-2018, 05:30 PM | #9 |
84
Rep 151
I have a 2019 M40i with 3,000 miles on it already, most of them at highway speeds. I have never noticed even the slightest vibration. 19" Alenza sport tires.
02-01-2019, 07:01 AM | #11 | |
56
Rep 188
(If you have some new findings please post it in the larger thread on this topic here https://x3.xbimmers.com/forums/showt...485010&page=31) |
