Engine not smooth while idle
07-15-2018, 03:36 PM | #1 |
72
Rep 381
Hi, I have idle similar to this video:
Happens regardless engine during warm-up or after a long drive. Does this mean ignition coil problem? Do I need to replace all 6 coils? |
08-09-2018, 09:58 PM | #2 |
Rep 111
same here
The same started on my car today (except of 5290 miles of distance-Lithuania)...
08-09-2018, 10:35 PM | #3 |
145
Rep 334
Shaft sensor.. if coils and sparks are good
JP
08-09-2018, 11:25 PM | #5 |
Art Collector
2427
Rep 3,448
As others have mentioned it could be a few things.
I had exact same symptoms. What worked for me was plugs first: this solved the problem for about 6 months. Then the problem returned, and I also started getting more pronounced misfires. Read codes, swapped coils, determined I had an issue so I replaced them all. Problem is gone. I’m sure my spark plugs weren’t actually to blame, but rather magnified the issue which in my case was caused by failing coil. |
08-11-2018, 07:26 AM | #6 |
148
Rep 388
I had the same thing. Even on a cold start the car would slighty miss. I put in Royal Purple DI cleaner and the car runs perfect now. Ran two bottles in a row with 40L in each tank. 1000 miles since and no issues. 8 bucks... Fixed it. Try that first.
08-12-2018, 04:11 PM | #7 | |
72
Rep 381
Also I scanned errors: 2F83 and 2F81 are there, what do they mean? could they be because of fuel injector cleaner? Or did I caught an issue? Last edited by Hotter; 08-13-2018 at 02:47 PM.. |
