F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > CIC to NBT Retrofit Part Check
GetBMWParts
      07-11-2018, 06:43 PM   #1
testcodes
Drives: BMW 328i
Hi Guys,
I'm planning on replacing my CIC with NBT. I'm getting the head unit and the screen from a nearby junk yard. I'm planning on keeping my current controller. From what I've read since I have a combox, I will have to run wires to the trunk. Or as an alternative, I can replace all the wiring and just hook them up behind the head unit and code out the combox.
So far I'm thinking I will need the following. I was wondering if you guys could confirm that I have the correct parts and that I'm not missing anything.
Emulator:
https://www.ebay.com/itm/Retrofit-Ad...AAAOSwbqpTs-M5
GPS Antenna:
https://www.ebay.com/itm/NEW-GPS-ANT...sAAOSw7hRWQ2VG
CID Cable:
https://www.ebay.com/itm/Car-Radio-N...kAAOSw0GNbEP5T
USB Cable:
Bluetooth Antenna:
Mic:
https://www.ebay.com/itm/BMW-CIC-NBT...EAAOSw~0paRLt1
One thing I'm not clear about though, for Satellite radio, I'm assuming I can reuse my current antenna since I'm guessing it runs to the roof and not to the combox?
Also, only good info I found on how to power the combox is from this thread, in which they mention to tap a black wire to the fuse box. Is this still the best way to power the combox?
      12-10-2018, 02:29 PM   #2
vilord
488
Drives: E91, Tundra, TT, SV650
Did you end up getting these parts? I'm trying to find the part numbers for the BT antenna cable and the two USB cables (center console and glovebox), but the part you linked to above is the CID cable 3 times.
Thanks!
f30post
