07-11-2018, 04:50 PM | #1 |
32
Rep 100
Tyre warning - What setting to use for Staggered setup?
Had a warning pop-up to say Tyre pressure needed checking.
All the tyres seemed ok, so did a reset and carried on as normal. Any ideas why that would happen? The pressures seemed fine, I didn't top them up as they were reporting the same as they always do. Secondly, I noticed in the tyre settings you can set what type of Tyres you are using, but the settings only let you choose one type of tyre size. I am on the standard summer tyres, but the 20" Staggered setup, with the wider tyres on the rear. So what setting do I use in the tyre settings section? At the moment, I selected OTHER. Anyone know the answer? |
