07-10-2018, 10:43 AM | #1 |
422
Rep 982
G05 Tire Sizes
Looks like rolling diameter is increased by up to 1 inch with the G05. Guess we won't be recycling wheels and tires. Bummer because I really like my winter setup...
- 265/50R19 vs. F15 at 255/50R19 (+0.4" Dia) - 275/45R20 vs. F15 at 275/40R20 (+1.0" Dia) - 315/35R21 vs. F15 at 325/30R21 (+1.0" Dia) - 315/30R22 vs. F15 at 325/30R21 (+0.7" Dia) Anyone heard any specs on hub diameter for the G05? |
07-10-2018, 11:45 AM | #2 |
4434
Rep 5,729
Drives: '24 iX50; '23 i4 M50
Don't forget the G chassis has 5x112 bolt pattern compared to 5x120
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
07-10-2018, 04:52 PM | #3 |
1729
Rep 3,654
07-12-2018, 12:20 PM | #5 |
56
Rep 257
Curious about those who get the 20”+ wheels on the X5. Is it just for looks? Where I am the roads are so bad that I usually go through a couple per year due to potholes. Was thinking of downsizing to 19” for some more sidewall and durability.
07-12-2018, 12:32 PM | #6 |
422
Rep 982
Ability to run performance tires in the summer, and looks play a factor for me also. Potholes not too bad where I am. If they were it would be a factor.
07-12-2018, 12:37 PM | #7 | |
396
Rep 525
My set of 22" 599M replicas would have looked really good on a new G05. Darn it. |
07-12-2018, 01:51 PM | #9 |
202
Rep 113
07-15-2018, 11:54 AM | #10 |
Rep 32
Does anyone else find it odd that the wheel specs in the ordering guide suggest the G05 wheels are narrower compared to F15?
For example: F15 469M 20" wheels are 20x10 front (275 tire) and 20x11 rear (315 tire) G05 741M 21" wheels are 21x9.5 front (275 tire) and 21x10 rear (315 tire) G05 742M 22" wheels are 22x9.5 front (275 tire) and 22x10.5 rear (315 tire) |
07-15-2018, 03:00 PM | #11 | |
615
Rep 314
07-18-2018, 12:49 PM | #12 |
369
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
Really!!!??????
Why? I have Pirelli winter tires on a set of 469's. Works great and I planned on using them on my 2020 M50i. Again, why can't they just be the same?
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra. |
07-18-2018, 09:03 PM | #13 |
Member
899
Rep 2,032
Drives: 2019 X5 40i M Sport
Garage List 2023 BMW M2 (HEA) [10.00]
2021 330i xDrive [0.00] 2019 G05 X5 M Sport [0.00] 2017 Jeep Grand Che ... [0.00] |
Damn! I guess I'll put up the F15's Winters for sale. By the time the G05 comes we'll be in Winter and snow. That's another added expense. This G05 is starting to add up.
07-19-2018, 06:23 PM | #14 |
Member
899
Rep 2,032
So I'm thinking of using the F15's Pirelli ice and Snow RFT's 315/35/20 and 275/40/20. Are there any current BMW rims that have the right bolt pattern and offset?
08-29-2018, 12:24 PM | #15 |
139
Rep 428
Mercedes is 5 x 112 with same bore as new BMWs at 66.6mm
Once we know the offsets for the X5, look for a Mercedes off a GL/GLS ML/GLE or maybe a heavy S-Class. The GL/GLS is high negative offsets like -56 to -60 ML/GLE is around mid 50s for negative offset S Class is lower. New Audi Q7 is also now 5x112 and same bore with offsets around -30 ish. |
10-14-2018, 04:03 PM | #16 |
154
Rep 440
10-21-2018, 12:03 PM | #17 |
Rep 6
Mine is getting delivered in November with 22" Summer Tires. Getting the 21" 741M Style Wheels to put on Winter Tires, but can't find them in the 315/35 R21 size for the rear. Anyone know where to possibly purchase them to match the front 275/40 R21?
10-21-2018, 12:29 PM | #19 | |
Plenipotentiary
2614
Rep 3,046
10-22-2018, 05:17 AM | #20 |
101
Rep 302
You could always use adapters, I think..
No Affiliation. https://www.ebay.com/itm/5x112-to-5x...-/171943677837 I'm not sure if we are allowed to post ebay links. Moderator, please delete if this is forbidden.
RUN FLAT TIRES? NEIN DANKE!
10-22-2018, 05:30 AM | #21 |
101
Rep 302
Or have a reputable shop CNC a new bolt pattern.
These guys in Georgia can do it, and apparently they can resize the hubs to the G05 as well. I don't know how the hell they would do that.
10-22-2018, 05:38 AM | #22 |
101
Rep 302
I have the old school BBS Style 101 wheels with the lip. I love these wheels with a passion. I had them bored out to fit my E70. I would love the bolt pattern changed to fit the G05. (If I ever buy one!!!!) These wheels use the large center caps that cover the lugs, so any imperfections in the machining (If any) would be covered.
