07-01-2018, 04:26 AM | #1 |
Regular user
224
Rep 965
Drives: F30 330D M-Sport Auto
Which size speaker for F31 front door upgrade
I'm buying an amp tomorrow to power the 6 speaker base stereo system in my F31.
Which size speakers should I opt for the front doors. 4"with adaptor rings or can a 5.25" be made to fit?
07-01-2018, 10:12 AM | #3 |
Regular user
224
Rep 965
I don't really want to go too expensive as I don't know how much I will be able to improve on the base setup.
Amp will be a 5 channel Alpine MRV-V500. 4x 40W and 250W for subs.
07-01-2018, 11:24 AM | #4 |
8245
Rep 16,088
Probably not much, if at all. I don't know if the drivers in the base setup are the same as those for the hi-fi, but my measurements of the hi-fi driver Theile-Small specs and response show them to be quite capable. I won't spend a dime on replacement drivers that aren't proven upgrades. OTOH you don't have tweeters. Adding them all around would be a decided improvement.
07-01-2018, 12:40 PM | #5 | |
Regular user
224
Rep 965
Will coaxial speakers be up to the job?
07-01-2018, 03:48 PM | #6 |
8245
Rep 16,088
Co-axials are great... if your ears are located on your knees.
Otherwise you want separate tweeters, as those can be placed closer to head level where they need to be. There are threads here that show how to add them. |
07-02-2018, 12:49 AM | #8 |
Regular user
224
Rep 965
Fair point.
The only options I can think of to add aftermarket tweeters are- Drill a new position them in the doors (probably would mean drilling a hole in the door too). Drill a hole in the blank A-pillar door trims (cheap solution, but wouldn't look factory). Buy the A-pillar door trims with the Harmon Kardon tweeter locations (expensive, but factory look). If there are cheap A-pillar trim replacements then I would rather go for them. Yep, all you get is 2 mids in the front doors, 2 mids in the rear doors and 2 subs under the seats ran from the front channels. The idea is that I separate the subs from the front channels to create a 6 channel setup and bridge the subs to mono and run a 5 channel amp. Once I know how that sounds on the standard speakers I can then look at upgrading the speakers. Essentially this is why I posted as I don't think that the door speakers will be up to the job, especially with no tweeters.
07-02-2018, 10:41 AM | #9 | ||
8245
Rep 16,088
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I put these in my rear doors, so I can vouch for them looking OEM there. Quote:
07-02-2018, 12:37 PM | #12 |
Regular user
224
Rep 965
True, but it has opened up my eyes to the possibility of buying non HK pillar trims if they're cheaper. That's something for me to look for on ebay perhaps.
07-02-2018, 12:41 PM | #13 |
Regular user
224
Rep 965
In the mean time I came back from the car audio shop after having a long discussion with the staff about my options. I was swayed to a better amp (a 5-channel Kenwood X801-5) and will try it out on the stock speakers.
Problem is that he suggested running it in stereo from the front channels as he believes that the rear channels are not full range. If this is this the case wouldn't I lose the beeping from my parking sensors if I don't the rear channels from the headunit?
07-02-2018, 12:45 PM | #14 |
102
Rep 216
07-02-2018, 12:56 PM | #15 |
4517
Rep 8,942
Bavsound will sell you the trims with their tweeter upgrades. That might be a good place to start.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
07-03-2018, 10:47 AM | #16 |
Regular user
224
Rep 965
Got the amp in today and wow, what a difference.
I'm no expert in sound quality, it's loud, but the quality tails off when you drive the stock speakers hard. I may well be looking in to replacements, but for now it's a million percent better. One thing though, the amp does get very hot. I assume it would shut down if this became a problem?
07-06-2018, 01:05 AM | #18 |
Regular user
224
Rep 965
Thanks. I think my earth may have been bad as I made the earth connection better and it seems to run cooler now.
