BMW X3 Forum
BMW X3 Forum
Welcome to the ultimate BMW X3 community.
      06-21-2018, 11:49 PM   #1
iManu
142
Drives: 2018 X3M40i
Just went to Icar drag strip today for the first time with the x3m40i.
I have BMS intake and Jb4 map 5 with 94 octane.
Turned off all BMW drivers assistance.
First run I did 12.3 in sports plus with launch control.
Second run I did 13.1 in eco pro mode with traction on and no launch control.
I'm surprised of the results! For a SAV this is pretty quick.
Draggy says I did 0-100kmh in 4.3 so the 0-60 would be around 4.1!
I also managed to do 0-60 in 3.99 with dragy gps measurements!
The biggest issue with this car is the heat, it gets slower after a few runs. Also the tires lose traction!
Appreciate 5
      06-22-2018, 12:05 AM   #2
kamek
358
Drives: 2018 X3 M40i
2008 BMW 328xi  [8.20]
Extremely impressive. Very well done and great to see our cars pushing limits!
      06-22-2018, 08:17 AM   #3
ParadigmDawg
ParadigmDawg's Avatar
610
Drives: 2019 AMG GLC63s
Ughhh....you just broke my 12.48@107.
I think I have a lot left in mine but fighting 100+ temp and 80-90% humidity right now.
My 0-60 is 4.15 on both map 3 and 5. The 1/4 mile falls off to 12.77 on Map 3.
I require 96 octane in these temperatures.
For the record, my times are via Dragy but I have run Dragy simultaneously with running at drag strip in my AMG and it has been dead on each time. I do spin all 4 wheels at take off when testing on the street.
These SAVs amaze me at their price point. There are very few cars on the street that I am not willing to take a shot at.
      06-22-2018, 08:56 AM   #4
iManu
142
Drives: 2018 X3M40i
Haha yes the conditions were good! 60% humidity and around 75 degrees. Also a good trick is to let your boost build up on launch control.
What map do you prefer 3 or 5? What's the difference? I find 3 is a little too jerky for daily driving.
For wheel spin, I plan on getting better tires. I'm sure I can go into the 12.2 territory with better tires!
      06-22-2018, 09:37 AM   #5
Sea-Tac
Sea-Tac's Avatar
1455
Drives: 2108 X3 xDrive30i
Didn’t someone post a better run a little while back?
      06-22-2018, 11:16 AM   #6
ParadigmDawg
610
5 is the best for me, my data shows it's screaming for Meth Injection but I am not sure I want to go there.
When I am on 93 octane pump gas for day to day driving, I use map 1-2.
On the days I am "hunting" I bump to 96 and run Map 5.
Yes, I let boost build during launch control but I am on the street not the track.
      06-22-2018, 11:35 AM   #7
j1980mac
263
You should go there.
      06-22-2018, 12:30 PM   #8
ParadigmDawg
610
Knowing me, I probably will....
      06-22-2018, 07:04 PM   #9
383vett
383vett's Avatar
626
Drives: 2018 X3 M40i, 2012 X3 Xdrive35
Nice numbers. Keep it up.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131
2021 SQ5
      06-22-2018, 07:54 PM   #10
Seaz
Seaz's Avatar
223
Drives: (2018,x3,m40) 2016,x3 2009,335
First wow , congrats man, I wish I was there tonight, could have been a m40 face off.
I've got a few questions since I cant get below 12.5 with 94 and same mods
1-How full was the tank
2- how much do you weight (yourself, I'm fat)
3- are you completely turning off traction control or putting it in DSC mode?
I see normal people , I'm not one of them
2018 X3 M40i - JB4
2016 X3 35i - JB stage 1
2009 335 e92 - JB4
      06-22-2018, 08:18 PM   #11
GT500R
800
Drives: BMW X3M
Nice work, any idea what the DA was?
      06-22-2018, 08:25 PM   #12
GT500R
800
Drives: BMW X3M
He has a slightly better 60' which leads to a better time. But you also need to compare the DA for each slip.
      06-23-2018, 09:21 AM   #13
iManu
142
Drives: 2018 X3M40i
Hi Seaz,
Would of been great if you were there too!!
Do you boost your turbo before launching? With the auto 8zf, it seems you can boost more if you wait longer in launch control mode. Also, this was my first run when my engine was cooler. I find the b58 heat soaks fast.
1-I had 1/4 tank.
2-I weight 165 pounds.
3-no I just pressed once the dsc button, if it's all off, then you lose launch control. But I turned Bmw safe collision sensors all off. Also, I don't have the roof racks and I didn't have a passenger!
      06-25-2018, 01:54 PM   #14
ParadigmDawg
610
List the DA that night please.
      06-25-2018, 06:47 PM   #15
iManu
142
Drives: 2018 X3M40i
Where can I find this info?
      06-25-2018, 07:25 PM   #16
GGEVOX
63
Drives: G01 M40i, F36 440xi
http://www.dragtimes.com/da-density-...calculator.php
Max Well4737.50
      06-25-2018, 08:51 PM   #17
javoyola
Drives: 2016 BMW 328i
I highly recommend using 100oct with map5. The difference is so overwhelming that you will notice it from the get go. Don’t believe me, just do it and be amazed. I’m planning a visit to the drag strip as soon as I can to put numbers down. It would be very cool because you could compare the differences. I also highly recommend connecting the Electronic Waste Gate cable for better results.
      06-26-2018, 08:41 AM   #18
Max Well
Max Well's Avatar
4738
Drives: '22 BG X3MC, '20 BSM X3MC
DA calculated for his run, documented in the G01 1/4 mile thread.
      06-26-2018, 10:19 AM   #19
ParadigmDawg
610
If you are turning good logs with 96 octane do you still think 100 would be better?
100 octane here is $10US/gal. I mix 93 and 100 for a 96 ratio.
This is me on Map 5. I could see where meth injection would bring down my trims but my timing is still rising the entire run so octane looks good.
      06-26-2018, 11:54 AM   #20
iManu
142
Drives: 2018 X3M40i
What octane booster is good to reach 100 octane? I don't know where to get higher octane here in Canada.
      06-26-2018, 01:00 PM   #21
ParadigmDawg
610
There is a lot of controversy around booster as it can eat up o2 sensors plus not really help that much. BMS has one they like and use but I don't remember which one. Email them and see.
I am certain there are real race cars in Canada or a race track? I just run to a nearby race track and get mine so look at that or find a shop that sponsors a race car and they should have a 55 gallon drum and they would likely sell you 5 gallons.
      09-06-2018, 07:27 PM   #22
iManu
142
Drives: 2018 X3M40i
New record!
Just beat my previous record! 12.315@110.45mph! Only jb4 and billet intake with 94 octane gas. The temperature helped!
