06-21-2018, 08:45 AM | #1 |
292
Rep 605
Exhaust valve modification
Has anyone consider/tried manually wiring the exhaust valves open, as people did with the F10, such that full sound is available on cold start up and idle? It seems that even with the exhaust button engaged, they only open in certain conditions. Anyone forsee any problems with doing this?
06-21-2018, 09:10 AM | #2 |
3619
Rep 4,532
You could try it. Easy to do since these are electric like the X5M. Turn the console button on, go to Sport Plus mode , rev the engine and unplug the connector at each valve. Flash a light into the pipe to insure they are open.
Did this on my X5M and had a slight drone at 1700rpm cruise. Replaced the system with Akra. The M5 is so quiet inside, it should be fine. |
06-21-2018, 09:44 PM | #3 |
292
Rep 605
I just pulled the connectors this evening, wrapped them in electrical tape, and zip tied them out of the way. Had to remove two retaining screws on each side holding the plastic skid plate to gain access. No codes thrown at startup, and definitely has that cold start growl I was wanting.
Green///Hell182.50 |
06-22-2018, 11:14 AM | #4 |
2035
Rep 1,843
Interesting.
I've done this on my previous X5M , with Manhart exhaust. Do you guys in the US have the M-Sport exhaust , with this button ? Last edited by Alberta; 10-28-2022 at 09:20 AM.. |
06-22-2018, 11:25 AM | #5 |
292
Rep 605
I have the standard exhaust, not M sport, as it was not available when I ordered. I do have that button, although even with that button on, the valves close on startup. Cold starts and low speed cruising are now much more energetic. You just have to make sure the flaps are open before you pull the connector wires, otherwise they will be stuck shut.
06-22-2018, 12:33 PM | #6 | |
3619
Rep 4,532
06-23-2018, 11:39 AM | #9 |
3619
Rep 4,532
06-23-2018, 10:45 PM | #10 |
292
Rep 605
09-25-2022, 08:28 PM | #11 |
4094
Rep 3,673
Drives: 2022 M5C
Does anyone have a photo of where to access these? Thank you!
Not a BMW guy...but certainly an M5 guy.
