06-21-2018, 12:35 AM | #1 |
Regular user
224
Rep 965
Drives: F30 330D M-Sport Auto
Speaker wire colours. And are the front speaker outputs full range?
I'm looking to add a DSP and amp to my 6 speaker base system for the front doors and under seat subs.
Can I use the the front door speakers outputs for the signal to the DSP? i.e. are they full frequency range? Does anyone know what the wire colours for these speaker outputs are?
06-21-2018, 12:59 AM | #2 | |
4490
Rep 10,473
muffking224.00 |
06-21-2018, 01:15 AM | #3 |
Regular user
224
Rep 965
Thanks.
Is there a way to tell if my BMW Professional system is the Base or HiFi system as there may be an option to use a harness if my car has a factory amp?
06-21-2018, 01:19 AM | #4 |
4490
Rep 10,473
06-21-2018, 01:33 AM | #5 |
Regular user
224
Rep 965
Thanks.
Just comes back with this:- Vehicle options L812A National version England / Ireland P337A M Sports package S1CAA Selection of COP relevant vehicles S216A Hydro steering-servotronic S230A Extra package, EU-specific S249A Multifunction f steering wheel S258A Tire with run-flat functionality S2NHA M Sport brakes S2PAA Wheel bolt retainer S2PFA BMW LA wheel M Star Spoke 403 S2TBA Sport automatic transmission S302A Alarm system S3AAA Roof railing black S3AGA Reversing camera S420A Sun protection glazing S423A Floor mats, velours S428A Warning triangle and first aid kit S431A Interior mirror with automatic-dip S459A Seat adjuster, electric, with memory S465A Through-loading system S481A Sports seat S493A Storage compartment package S494A Seat heating driver/passenger S496A Seat heating, rear S4DLA Accent strips, black, high-gloss S4MRA Interior strips, aluminum hexagon S502A Headlight cleaning system S508A Park Distance Control (PDC) S520A Fog lights S521A Rain sensor S522A Xenon Light S524A Adaptive Headlights S534A Automatic air conditioning S544A Cruise control with brake function S563A Light package S575A Supplementary 12V sockets S5ACA High-beam assistant S5DAA Passenger airbag deactivation S5DCA Rear-seat headrests, folding S5DPA Park Assistent S609A Navigation system Professional S654A DAB tuner S698A Area-Code 2 for DVD S6ACA Intelligent emergency SOS call S6AEA Teleservices S6AKA Connected Drive Services S6AMA Real-Time Traffic Information S6ANA Concierge Services S6APA Remote Services S6NHA Hands-free with USB interface S6NRA Apps S6WAA Instrument cluster, expanded equipment S6WAA Instrument cluster, expanded equipment S704A M Sports suspension S710A M leather steering wheel S715A M Aerodynamics package S760A High gloss shadow line S775A Headlining anthracite S850A Dummy-SALAPA S853A Language version English S880A On-board vehicle literature English S8KAA Dummy-SALAPA S8S2A Coding alarm signal S8S3A Automatic locking when driving off S8SMA Car ident. number visible from outside S8TGA Thiefproofing device S8V1A Label
06-21-2018, 04:03 AM | #6 |
67
Rep 240
From the VIN decoding your vehicle is the same as mine and that is it has the pro nav (S609A) but it will have base stereo ie. a mid in each door and a sub under each front seat.
There is no separate amp - the iDrive head unit drives everything and carries out the EQ as well. I was looking at upgrading similar to you but never got around to it - all I did was upgrade the mids in the front doors and added tweeters at the front via a rainbow upgrade set ! You can still use a harness from technic to upgrade the base system - see https://technicpnp.com/ HTH Andrew Last edited by andrew.webber; 06-21-2018 at 04:10 AM.. |
muffking224.00 |
06-21-2018, 09:49 AM | #7 |
Regular user
224
Rep 965
I can see why you didn't take it on, a lot of wiring from the front.
I'm thinking if I can use the Autoleads SOT-976FB Fakra cable. https://www.ebay.co.uk/itm/SOT-976FB...19.m1438.l2649 I believe it's supposed to allow ISO speaker connections to be used inline between the headunit and speakers. That way I can run cables to an amp and back. Does that sound about right?
