06-20-2018, 10:37 AM | #1 |
Regular user
224
Rep 965
Drives: F30 330D M-Sport Auto
Show us your amp installation
As we all love pictures and I'm trying to get ideas on how to install my amp, can anyone post pictures of their installations. Specifically where to run power & speaker cables, plus where/how to mount an amp.
I'm just in the process of buying up the bits to start on my F31, so any ideas would be great.
06-20-2018, 12:05 PM | #2 | |
4516
Rep 8,942
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
scostu1623.00 |
06-20-2018, 01:04 PM | #4 |
4516
Rep 8,942
Yeah I'm waiting on the ASD harness. I already swapped stock amp for Bimmertech and prewired for a JL XD600 w/ Focal P25F.
2022 Macan S
scostu1623.00 |
06-20-2018, 02:37 PM | #5 |
Regular user
224
Rep 965
Should I run the the main speaker outputs via an Audiocontrol LC2i to feed both the door speakers and the under seat subs, or should I run independent amps for doors and subs?
06-20-2018, 04:03 PM | #6 |
63
Rep 62
Built a 2 tier amp rack, and put it in the big storage spot in the trunk. Bottom shelf holds the mObridge DA3, and Helix DSP-Pro II Top shelf holds a pair of MMATS HiFi 6150 amplifiers. I drilled a big hole between the battery compartment and the storage spot, to run the power wire. |
muffking224.00 |
06-23-2018, 02:38 PM | #8 |
4516
Rep 8,942
I did a quick fit on the Poland sub enclosure - the quality is very very good and the fit is spectacular. The carpet is a dark grey and doesn't quite match but that doesn't really bother me. I'm going to add a little Velcro to it and call it done. If you get from their site vs eBay it's $167 and well worth it.
2022 Macan S
scostu1623.00 |
06-23-2018, 03:07 PM | #9 | |
1623
Rep 2,036
06-23-2018, 03:10 PM | #10 | ||
4516
Rep 8,942
2022 Macan S
scostu1623.00 |
06-26-2018, 10:17 AM | #11 |
Rep 26
You can ignore the finger in the photo...I was exhausted from all day of getting this installed.
Sub is a Sundown Audio E8v.5 and amp is an SAX125.4. I believe I'm running 30-40 watts to each underseat and 350ish to the trunk sub. I wanted a single amp to run underseat subs and trunk woofer, LC2i and X-over are mounted to the bottom side. Wires are run through holes drilled in the sides. The ported sub enclosure will get redone at some point, just not sure when that will be hence the duct tape holding the port together. I had tried a sealed sub before but just didn't suit my taste. I'm pretty happy with it as it is now. |
muffking224.00 |
06-26-2018, 04:44 PM | #12 |
Regular user
224
Rep 965
I'm loving the use of the Clamp Meter to check if the power cable is up to the job
06-28-2018, 02:06 PM | #13 |
Rep 26
My first time using this amp, some what curious what kind of power it would put out. (I know Sundown stuff so I pretty much knew it would do rated power)
I also had an idea where my previous setup was power wise so made it easy to match the output when I swapped in the new amp. Compared to what I had on the underseat woofers before(ppi600.2) there is a definite sound difference...It's amazing what a difference a quality amp can make. |
07-06-2018, 01:16 AM | #14 |
Regular user
224
Rep 965
Very true.
I now have a Kenwood X801 5 channel amp running my 6 speaker system via an ISO extension lead running from the headunit to the boot and it made a huuuuge difference. I think I will update the front door speakers and maybe add tweeters, but that's all it really needs.
07-14-2018, 01:00 PM | #16 |
8245
Rep 16,083
Isn't that with the base radio? If so the amp contained in that head unit probably runs no more than 10 watts/ch. The Kenwood wouldn't do much for the hi-fi radio, if anything, let alone the Harmon.
07-14-2018, 02:50 PM | #18 |
4516
Rep 8,942
Ill get around to a write up one of these days. Great fit very happy w build quality. Need to trim trunk liner then all done.
2022 Macan S
scostu1623.00 |
08-28-2018, 10:22 PM | #19 |
187
Rep 231
I'm going to be installing an amp in the underneath cubby in the near future.
Any recommendations how/where to run the main power line from the battery? I'd prefer not to drill through the bottom of the trunk for fear of rust in the future. Any alternative locations to run the wire? If drilling is a must, where is the best place to do so? Pics would be greatly appreciated! |
08-29-2018, 01:30 AM | #20 |
Rep 78
Hopefully not a thread jack... does technic still make harnesses? Does anyone make custom sub enclosures? I need a 12" enclosure for a F36. Thanks!!
I'll post pics when I get these setup and installed |
08-29-2018, 02:34 AM | #21 | ||
Regular user
224
Rep 965
https://www.ebay.co.uk/itm/ISO-SOT-0...EAAOSwMEBaql6R
08-29-2018, 07:00 AM | #22 | |
187
Rep 231
However I think Technic is no longer providing any advice/support whatsoever. The package I received had the harness & two loose connectors only. No wiring diagram, no instructions, nothing else. I tried PM'ing Technic's account on here, didn't work. So I sent a message to his website where I bought the harness from asking for a wiring diagram, but received no reply. A little frustrating because I want to both add a subwoofer and have an amp power the under-seat woofers which I know can be done with his harness, but I guess I'll have to figure it out trial and error...... |
