06-19-2018, 12:20 AM | #1 |
84
Rep 138
F30 seden rear suspension
Hi all,
I'm planning to replace the stock suspension to damper adjustable coilover (adjustable knob on the top), may i know if it is possible to adjust the rear damper setting without removing the coilover every-time, since the knob is located on the top of the coilover, thank you
2012 BMW F30 328i
06-20-2018, 07:22 AM | #2 |
479
Rep 797
There is no access to the top of the rear shock through the trunk with the F30. It sucks. You have to lift it, pull the wheel, and unbolt the shock mount in the fender well (3 small etorx bolts .. I dunno the size #). You will probably be able to compress the shock enough to get the mount down, pry up the little plastic thing, and make your adjustment with it still bolted into the lower arm. But you may find it easier to remove the lower shock bolt and drop it all the way down.
I only had to do this 3 times until I got it right... |
manghong84.00 |
06-20-2018, 09:49 AM | #4 | |
84
Rep 138
2012 BMW F30 328i
06-22-2018, 10:59 AM | #5 | |
Modder of everything I own
147
Rep 491
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
kern4174449.50 |
