Clunk coming from the front end...
06-12-2018, 08:47 PM | #1 |
660
Rep 780
EVery time i first move the car of every once in a while when turning the wheel in the parking lot at low speeds i get this "clunk" noise coming from the front end. Any idea where i should start with diagnosing it? The car has 140k on it. I had it since 100k and never replaced anything with the suspension components.
06-13-2018, 09:23 AM | #2 |
521
Rep 1,485
more then likely bushings from one of the control arms needs to be replaced or the bushing from the sway bar end links need to be replaced.
you will need to examine the suspension to be sure. |
06-13-2018, 11:17 AM | #3 |
718
Rep 1,753
lift the front up remove the wheels start turning the steering wheel start listening...
but other than that i would replace all control arms and thrust arms as well as shocks if you plan on keeping the car. |
06-13-2018, 09:47 PM | #4 | |
Rep 77
the struts were also leaking so those were replaced, after that everything was good to go, but the bushings were the biggest improvement |
06-13-2018, 09:50 PM | #5 |
287
Rep 1,710
Bushings. Had it on my car a few months ago. Bushings are filled with liquid so when that's gone you get the clunking sound. Upgrade your front control arms to M3 standard with M3 bushings or a good monoball bushing.
DONE: Seibon CF Hood, M3 Rep, MSport rear w/DD CF Diffuser, M3 Rep Skirts, Seibon CSL trunklid, Forgestar F14 18s w/Michelin PSS, Eisenmann catback, AA Headers, BPC Stage 2, Charcoal Delete+revMotor+AFE Drop In filter
FUTURE MODS: LED headlights, CF rooftop, M3 Suspension Conversion, Dinan CAI Mod |
06-13-2018, 11:26 PM | #6 |
BMW Enthusiast
51
Rep 193
Could be the wheel bearings, I had the same issue last year and had replaced the front wheel bearings myself. After that no more clunking noise! Very easy to diy. My car is high mileage like yours just for reference, I'm currently at 142,000 miles.
06-14-2018, 12:37 AM | #7 |
729
Rep 1,815
I just diagnosed a bad strut top bearing on my e87. the symptoms were a clunk sound a low speeds and turning at low speeds on the right front side. This is a generic video but maybe it will help.
2009 118i Monaco Blue "Maximillion"
2009 335i Saphire Black M Sport "Leopold" Cobb stage 2 aggressive tune, Mishimoto FMIC, Cobb charge pipe, Cobb catted down pipes, Forge diverter valves, BMS inlets and DCI, Cyba scoops and M Individual Audio retrofit and M3 gauge cluster retrofit. 2011 328i Titan Silver M Sport "Franzel" <--Wife's car |
06-14-2018, 07:55 AM | #8 | |
1903
Rep 6,968
06-14-2018, 09:48 AM | #9 |
660
Rep 780
If i start with control arms, im not sure if i should get the M3 arms or OEM. I like the performance/precision that you'd get with the M3 arms but i do enjoy the drive-ability and comfort of mine right now. Anyone here have experience with both?
06-14-2018, 10:05 PM | #10 |
Rep 4
Vibration heavy
I have a heavy vibration upon accerlerating and only after engines warmed up.
I just changed the center bearing and flex guibo disc on driveshaft to no luck. Still a heavy vibrstion 30+mph. Idk if its the torque converter, cv joints/axle, or low tranny fluid. All i know is a heavy vibration upon accerlerating and goes away it i let off the gas. Happens are low or high speed just not as bad. Only thing i know is Lower control arms need work and we thought the driveshaft bearing and disc would fix the issue. |
