Body Control Module
06-12-2018, 12:56 PM | #1 |
10
Rep 46
Body Control Module
Hi, I have BMW E91 (2005) auto diesel. Body control module has became faulty. So I have another module in place but it is not exactly from the same car model and some of the electronics are not working properly. Can it be coded or does it need replacement with the exactly same as the original? If it can programmed, it would be great to get some guide/material on how to do it. Thanks!
06-13-2018, 03:47 PM | #2 | |
529
Rep 2,503
Try coding the JBE to default with NCS |
06-14-2018, 03:47 PM | #3 |
10
Rep 46
Hi Sensible, I have managed to get the original part with same part number and most of the things are working now. Yay! Unfortunately, when I try to connect INPA, it does not recognise and gives me error. I had different diagnostic software to try and diagnose but it also does not communicate with car. What can it be?
06-14-2018, 05:44 PM | #4 | |
529
Rep 2,503
06-15-2018, 01:53 AM | #5 |
10
Rep 46
06-15-2018, 02:08 AM | #6 |
461
Rep 2,759
the modules untill 2007/03 communicate using K-line protocol
the modules after 2007/03 communicate using DCAN protocol so you need to check what car is manufacturing date of the car and what version of the module you installed instead
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes. |
06-15-2018, 03:10 AM | #7 |
10
Rep 46
Right. The module I have installed was exactly same part number, H4, manufacturing date 2005 (same as original). My E91 was manufactured in late 2005. I have the following cable: https://rover.ebay.com/rover/0/0/0?m...2F112889244545
Any thoughts? |
