New engine
06-11-2018, 06:40 AM | #1 |
74
Rep 295
New engine
Recently my car had a slight shake to it. Had it read and it was a few misfires so i went and did my spark plug and coil change myself, didnt do it correctly brought it to my shop to have it fixed. They fixed it and a week later late night after work i was parking my car, out of no where my car started to shake really bad, it was so bad that i had to get it towed to the shop to have it checked up. Got it read and my mechanic told me there was misfires again so they put in new coils and spark plugs , still had the really bad shake, reason why he told me is that theres no compression going to one of the cylinders in the engine so i had to replace my engine. Estimate was 2,500 for used motor and labor. My original engine had 130,000+ miles. I'm thinking is this even worth doing and just getting rid of the car, need opinions. thank you
06-11-2018, 06:54 AM | #2 | |
102
Rep 343
Do you have any idea as to why you think your motor failed? |
STRMTRPR74.00 |
06-11-2018, 08:02 AM | #3 | |
74
Rep 295
06-11-2018, 08:26 AM | #4 | |
132
Rep 573
I would replace if everything else is in good condition. Ask for 1) a compression test and 2) a leak down test they might just be pulling your leg without doing much work how trustable is this shop always get a second opinion $200 towing and diag from another shop is worth if it's going to save you $1-$2k these engine can misfire for various reason it doens't always mean i'ts low compression. if it's a 07/08 read up on MOSFETS http://www.e90post.com/forums/showthread.php?t=986168 |
06-11-2018, 08:30 AM | #5 | |
74
Rep 295
06-11-2018, 09:27 AM | #7 | |
205
Rep 349
06-11-2018, 09:48 AM | #8 | |
1903
Rep 6,968
If I were to get a rebuilt engine, I would look into MMP. For $3500, you get a lot of piece of mind and a few upgrades. https://mmp-e.com/products/n54-built-engine-program |
06-11-2018, 09:55 AM | #9 | |
Hoonigan
6848
Rep 3,000
Drives: '09 328i, '98 Wrangler
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
06-11-2018, 09:58 AM | #10 | |
Hoonigan
6848
Rep 3,000
Rebuilding one of these will likely cost more than it is worth. They are fairly complex, and you basically have to hope and pray the person doing it knows what the heck they are doing. These aren't short block Chevys. I'd trust a good used factory built engine over a cheap rebuild.
06-11-2018, 12:49 PM | #12 |
125
Rep 445
About 3 months ago I experienced very similar symptoms, Had zero compression in cylinder 4 and low compression on cylinder 5. Leak down test pointed to ring lands. I heavily maintained the car and honestly don't know what happened. It was just FBO with an mhd tune. Ended up buying a salvage car from the auctions and doing a manual trans conversion and engine swap. bought the car for 2k ended up selling around 4 k in parts off it so it was a small profit for me.
2008 E92 335i-MHD FBO-6MT Conversion- CIC I-drive Retrofit
feuer4275.50 |
06-11-2018, 12:49 PM | #13 |
Art Collector
2425
Rep 3,448
Am I wrong to think that $2500 isn't all that terrible? I've never looked in to engine replacement though, so I don't have a flying fuck of a clue what's normal.
Considering the alternative is to plasma-cut out the driver and passenger footwell and go Flinstone, I'd give serious consideration to the engine replacement |
feuer4275.50 |
06-11-2018, 12:56 PM | #14 |
Crazy Frog
543
Rep 1,211
Not sure if I read that correctly but $2,500 is cheap as fuck for a used N52 motor plus labor to install it.
A used N52 with 70k to 100k miles already costs $1700 to $2000. The labor on an engine out procedure is billed at 12 - 15 hours of labor. So even at $100/hr labor thats another $1,200 to $1,500 to install it. I'd say $2,500 for part & labor is a damn bargain and you should go for it! As long as the used engine has a warranty (90 days or something).
feuer4275.50 |
06-11-2018, 01:32 PM | #16 | |
2188
Rep 5,002
2 - lots of motors blow and almost always has nothing to do with the owner. Stress testing by manufacturers is incredibly rigorous and these motors are tanks sooooo it’s a manufacturing defect more than likely. Also, you were banned. Why are you back Straight6? Please leave |
06-12-2018, 05:48 AM | #17 | ||
1903
Rep 6,968
STRMTRPR74.00 |
06-12-2018, 06:51 AM | #18 |
74
Rep 295
06-12-2018, 06:53 AM | #19 | |
74
Rep 295
06-12-2018, 06:57 AM | #20 |
74
Rep 295
The rest of the car is perfectly fine, i do most of my DIY's except big things. Right now this situation just happen right when i finish school lol, new bmws (fx's) dont really please me with looks and performance.
06-12-2018, 07:40 AM | #21 | ||
1903
Rep 6,968
STRMTRPR74.00 |
06-12-2018, 08:39 AM | #22 | |
74
Rep 295
