Can't adjust loose hand brake?
06-10-2018, 10:39 PM | #1 |
Crazy Frog
543
Rep 1,211
I did a brake job on my 11' 328 sedan. Brand new rotors at all 4 corners and new front pads.
The handbrake became extremely loose after the brake job. I can pull it all the way to the top and it still does not engage car. There is basically ZERO resistance to the hand brake handle. I followed the DIY hand brake adjustment guide from Pelican Parts, Youtube, and some on this forum but my hand brake is still not tight. I pushed the service lock spring in, then tightened the passenger side by scrolling the wheel down and the driver side by scrolling up. I have scrolled it so many rotations but the rear wheel still spins freely. What's going on? Am I scrolling the correct direction to tighten/loosen?
06-11-2018, 11:07 AM | #3 |
2685
Rep 4,202
Drives: '11 335is | '16 Macan Turbo
Try reversing at 10'ish mph and using the hand brake to stop
'11 335is BSM MT "BMW Performance Editon" | '16 Porsche Macan Turbo
GruppeM CF Intake | AR Resonated DP | ER CP | Turbosmart RacePort BOV | Cobb FMIC | RB Inlets | RB External Mishi/Turner OCC | Michelin PS4 | BMW Performance Springs/Bilstein B8 + Dinan & M3 bits | BMW Brembo BBK | BMW Performance CF Spoiler | BMW Performance CF Lip | BMW Performance Alcantara | PS Designs GTS Armrest | AG H6-40 | Rear Seat Delete |
06-11-2018, 11:51 AM | #4 |
310
Rep 1,016
100% sure you have 100% the right rotors for your model BMW. I had the same problem as you and it turned out shitty part store sent me rotors for the wrong model BMW. The rotors fit but they were to big where the e brake grabs.
06-11-2018, 12:33 PM | #5 |
Crazy Frog
543
Rep 1,211
Lol....I wouldn't be able to stop at all. The hand brake does not work, period! I can pull the lever all the way up and still nothing.
06-11-2018, 12:34 PM | #6 |
Crazy Frog
543
Rep 1,211
Thanks for the suggestion. I'm gonna go check the part number right now.
06-11-2018, 12:38 PM | #7 |
2685
Rep 4,202
Try it... a few times. After that, then ya you got a problem
BimmerNugget542.50 |
06-11-2018, 12:39 PM | #8 |
Crazy Frog
543
Rep 1,211
Part number for the rear rotors are Centric 12134091 (C-tek) from RockAuto. Rockauto says they fit 328i from 2007-2013. I assume this includes both Coupe and Sedan? I have a E90 sedan.
06-11-2018, 12:58 PM | #9 |
310
Rep 1,016
rockauto is a pretty good company I am sure they are right. If you have your old rotors that would confirm if they are right or not.
06-11-2018, 02:48 PM | #10 |
2341
Rep 3,539
You have likely dislocated the parking brake shoe mechanism on the bottom or the cable slipped out of it.
Remove the discs and inspect all components of the parking brake. |
06-14-2018, 12:50 AM | #11 |
Crazy Frog
543
Rep 1,211
Found out why my handbrake isn't working. RockAuto's catalog gave me wrong part.
Centric 12134091 is for Convertibles and Wagons (E93 and E91) not Sedans. Their stupid catalog didn't even mention the body style or have a little note saying its for verts and wagons. I'm gonna see if I can return it and get the correct part.
06-14-2018, 07:36 AM | #12 |
Art Collector
2425
Rep 3,448
Glad you got this figured out. And thank you for sharing your experience.
RockAuto has always been great for me so I don’t even think twice. Now I’ll make sure to double-check PN’s! |
09-22-2018, 12:08 PM | #15 |
Crazy Frog
543
Rep 1,211
Just an update, RockAuto took back the rotors without a fight even though I had already installed them and driven around 100 miles. They even paid for return shipping. They made me whole again, so I'm happy and will continue to use and recommend them.
I went ahead and ordered the rear rotors right after I got my refund, installed them in June and everything's been great ever since.
09-22-2018, 12:40 PM | #16 |
2188
Rep 5,002
Bingo, Rockauto is awesome.
And yeah, never trust a 3rd party for part verification. Go straight to bmw a la realoem.com then once you have good part info buy from cheapest/best supplier. |
09-23-2018, 09:42 AM | #17 | |
310
Rep 1,016
10-08-2018, 03:38 AM | #18 |
Rep 70
Found out Amazon "vehicle checker" didn't know there are 2 different part numbers depending on whether it's a coupe\convertible or a sedan. They were good and shipped me the correct ones and an RMA label to return the others. Got my E brake back now👍
10-08-2018, 03:06 PM | #19 |
252
Rep 1,157
10-09-2018, 12:22 PM | #20 |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
Sounds like a broken cable to me.
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
10-09-2018, 12:24 PM | #21 | |
945
Rep 1,507
10-09-2018, 01:25 PM | #22 | |
Robot
1685
Rep 2,191
Fortunately in this case there are pictures of the parts and it's obvious to me which one is correct for my car, but this can be very confusing in cases where the part differences aren't as obvious to everyeone. When I replaced my valve cover gasket, I ordered the one that the Rock Auto catalog listed but it ended up being the wrong one since I needed the gasket for the magnesium valve cover. Rock Auto incorrectly listed one for the plastic cover as compatible with my car, and that's what I mistakenly ordered/received because I wasn't aware of the differences at that time. Last edited by lowrydr310; 10-09-2018 at 01:30 PM.. |
tlow982188.00 |
