Maintenance Suggestions
06-06-2018, 10:28 PM | #1 |
Rep 35
Hello All,
So, I am compiling a list of all the things I would like to do to my car, primarily for my own peace of mind, as well as to establish a sort of "baseline" for any maintenance to follow. Listed below is what I plan to do and or have done, in order of importance. 1) New Coils/ Spark Plugs (Delphi Coils and NGK Spark Plugs, car has a misfire occasionally, and tends to idle rough occasionally) 2) Coolant Flush (Previous owner put green coolant in it, to my dismay I only discovered this after adding some Zerex G-48) 3) Alignment/Check Brakes 4)New Air Filter/Cabin Air Filter 5)New Brakes (Depending on the results of #3) 6) Automatic Transmission Fluid change? 7) Oil Filter Housing Gasket 8) ??? I know this seems like a lot, the previous owner neglected a lot of her needs, so I am having to make up for lost time, hopefully with no adverse effects. I think I have listed the main things. My main reason for posting this is to ask, is there anything I missed that I should be doing? Is there anything I should be aware of when doing or having these things done? I will be taking it in for everything except spark plugs, coils, and filters. I just don't trust myself enough yet to do anything else. Sorry for the lengthy post, and thanks for any help you can provide! |
06-06-2018, 10:57 PM | #2 |
could-be bmw tech
17
Rep 71
Drives: %E2%80%9809 335i
fyi oem coolant should be green/blueish
Depending on your milage you can check the suspension components like strut mounts that tend to deteriorate at high milage, blower fan area if you haven't had the recall replaced, consider a water pump replacement (hopefully your car already had this), I'm sure theres plenty more but I can't think of any at the moment
Jet black e90 335i LCI | MHD/xHP | BMS DCI | ER cp w/Synapse BOV | ST coilovers | mufflers are still there
06-07-2018, 04:59 AM | #3 | |
102
Rep 343
I’d recommend an oil additive/flush, or even trying an oil change interval with shell rotella. Some owners on here have tried it and said it worked great for cleaning out an engine with deposits. - service the caliper sliding pins with a copper-free brake grease when you change your brakes. (Not sure why BMW doesn’t suggest this, I did it during a brake service and the brakes felt fanstastic afterwards) Even if you’re not changing brakes a brake fluid flush would be a good idea. - inspect belts, tensioner, pulleys. If your tensioner is wobbling like this, replace it: https://youtu.be/rPRxObxYc0k - rotate tires. (Again, not sure why BMW doesn’t recommend this (unless you’re staggered of course) - change solenoids and valve body along with transmission fluid change - fuel injector/fuel system cleaner - full detail in and out and paint wax - ensure suspension is in good shape (tie rods, bushings, lower control arms, struts, etc) - differential fluid change - inspect oil filter housing, oil pan and valve cover gaskets |
06-07-2018, 07:19 AM | #4 | |
Art Collector
2425
Rep 3,448
This would be an absolute last (or second-last) resort if one was experiencing issues that could be directly linked to VB deficiencies/pressure issues, and that could not be solved by replacing valves, springs, etc within the valve body (rebuilding it). The rest of your list is great, but in my opinion this is not a maintenance item... |
floydarogers690.00 tlow982188.00 |
06-07-2018, 08:05 AM | #5 | |
102
Rep 343
you don't need to change it if you don't think it's necessary, but I would strongly recommend replacing solenoids while you're in there. |
06-07-2018, 01:40 PM | #6 | |
1903
Rep 6,968
06-07-2018, 02:28 PM | #8 |
130
Rep 315
At 151k for a 2009, I would make sure the transmission filter has been changed as well. Including your original list, my votes would be for the valve cover+gasket, differential fluid, water pump and thermostat (as other posters suggested).
I'm at 100k, and about to change all of the items I just mentioned and the spark plugs+coils (I changed the transmission fluid and filter at 93k). |
06-07-2018, 02:49 PM | #9 | |
Curmudgeon and Pedant
690
Rep 3,489
I would add: "When changing the transmission fluid, inspect the mechatronic sleeve and replace if leaking". One might also consider buying a metal pan to replace the plastic one. |
06-07-2018, 03:31 PM | #10 |
Rep 35
So, Slight changes to the list, I will be doing the Oil Filter Housing Gasket swap next week and will be doing it first. I made sure to order the OE gasket and replacement bolts. I was looking over the service summary from my last time at the shop and noticed they said it was leaking. Surprisingly, I will be replacing it myself (Independent shop wanted to charge $405 JUST for labor, absurd). I am not sure if the valve cover gasket has been replaced, I think it may have already been but I am not sure. How would I check to see if this needs to be done? I am not sure if I would be able to do that myself.
06-07-2018, 04:49 PM | #11 |
Rep 35
Update, Need Help!
I have procured the previous owner's service records, and have found some interesting things. If anyone would be willing to help me figure out what happened based on these I would greatly appreciate the help. Below I will summarize as best I can what the service records indicate.
1) So at 113k miles, he had 6 spark plugs changed and the Valve Cover Gasket replaced. Okay, no big deal. 2)Now, AGAIN, at 113k miles, the shop requested the following be done to the car: Terraclean Engine Treatment New Oil Filter New Oil Terraclean Engine Clean Valve Cover Valve Cover Gasket At this point, he declined all of the above and, I assume, continued driving it. 3)At 120k, they again requested a Valve Cover and Valve Cover Gasket Set, which he also declined until... 4)...At 121k, They requested a new Valve Cover and Valve Cover Gasket, as well as a Leak Pump. He accepted all of these and had the work done as far as I know, as only the Valve Cover Gasket Set says "returned" beside it on the invoice. 5) Finally, at 136k, he had the oil changed, but the shop also requested to do a Oil Pan Gasket replacement, but he declined this. Shortly after this he sold the car to me. Now, I am not sure what I should be replacing with this in mind, or why the shop kept wanting to do all of the work to the Valve Cover area or to the Oil Pan Gasket. I will call in the morning to see if I can secure some technician notes that seem to be missing. My only idea is that they may have been trying to nail down some sort of oil leak? I know the car had a slight history of occasional misfires and evap leaks. I had a smoke test done and no signs of evap anywhere. How should I proceed with all this in mind? Sorry for the lengthy update, I would really appreciate any advice you guys can provide! |
06-07-2018, 07:35 PM | #12 |
690
Rep 3,489
Sounds like a lot of make work to me. If you can stand a couple drops on your garage floor, why bother? An oil pan leak is never going to threaten the engine; and a new one will likely leak, too.
06-07-2018, 08:01 PM | #13 |
1903
Rep 6,968
06-07-2018, 08:08 PM | #14 | |
Rep 6
While you're at it with your maintenance list add a good engine washing to the mix. Pretty easy to do and will give you a good idea if you have any leaks anywhere since any old oil residue will be gone and not give you any false oil sightings. |
06-07-2018, 08:31 PM | #15 |
Rep 35
06-08-2018, 07:19 AM | #16 | |
1903
Rep 6,968
06-08-2018, 08:18 AM | #17 |
Rep 35
06-08-2018, 12:32 PM | #18 |
1903
Rep 6,968
Yep. No problem. Make sure to include the year and type of car (335 or 328) and if it's AWD or not.
06-08-2018, 02:01 PM | #19 |
Hoonigan
6849
Rep 3,000
Drives: '09 328i, '98 Wrangler
At 150k miles, I would check the condition of your cooling system hoses. Many of them are plastic and get brittle over time. One broken plastic hose can empty your cooling system pretty quick.
The upper and lower radiator hoses aren't all that expensive and snap into place.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
06-08-2018, 03:00 PM | #20 |
Rep 26
The VCG I would only change if needed, meaning smell of burning oil or alot leaking out between oil changes. I put 6 e3 spark plugs in mine and I love them. I have only been changing coils as needed, so far just one but I ordered 2 to keep one as back-up. Good luck...
06-08-2018, 04:25 PM | #21 | |
2188
Rep 5,002
With that being said I’d never do them unless there was an actual issue and even the i’d Try the trans fluid first. They either work or they don’t. Preventative replacement is a waste of money/time. |
06-08-2018, 04:33 PM | #22 | |
102
Rep 343
Tags |
maintenance, newbie, questions |
