When bleeding cooling system, is a trickle charger required?
06-06-2018, 06:14 PM | #1 |
Crazy Frog
543
Rep 1,211
I plan on doing OFHG soon and some coolant needs to be drained, thus air will enter the cooling system when I'm done and a bleed procedure will be needed.
When bleeding the system, many people say to plug in a battery charger to prevent the battery from draining. Is this necessary? My battery is fresh, only 1 year old and I recently took my car on a little road trip (300 miles), so the battery should be fully charged by the alternator. The bleed procedure takes 12 minutes, will the water pump really drain a fresh battery in just 12 minutes of usage?? I'm really trying to save that $40 and not buy a battery tender if I don't have to.
06-06-2018, 07:25 PM | #2 |
205
Rep 349
Just get another car, run it and parallel the batteries. That's how I bled my cooling system.
Biginboca3763.50 BimmerNugget542.50 |
06-06-2018, 07:54 PM | #3 |
3764
Rep 2,738
06-06-2018, 08:45 PM | #5 |
Art Collector
2425
Rep 3,448
You’ll be fine without one.
I ran the bleed procedure multiple times on my quite-new battery and no issues at all. |
06-06-2018, 08:51 PM | #6 |
Crazy Frog
543
Rep 1,211
Ehh, I'd rather not spend $40 on something that's only going to be used 1-2 times. All my cars are daily driven, it's not like I have a Ferrari 488 garage queen that needs to stay charged when it's not driven for extended periods. Also, I'm not one to buy a tool, use it, then return it. If it's not 100% necessary for this process, then I won't get it. Thank you for your responses.
e90yyc2425.00 |
06-06-2018, 09:52 PM | #7 |
397
Rep 433
Drives: 2008 BMW 335i sedan
A trickle charger wouldn't do anything for you here. A typical trickle charger puts out around 1 Amp. Assuming you had it on the battery for the entire 12 minutes during the bleed procedure, that is 1 Amp x 12/60 Hr = 0.2 Amp-Hr. That is 0.2% of the capacity of a typical 90 Amp-Hr 335i battery. Even a full capacity 10 Amp charger isn't going to do much in 12 minutes: 2 Amp-Hr or ~2% battery capacity. I don't know what the current draw for the electric water pump is, but I can't imagine it is more than 20 Amps at its highest speed which translates to ~4 Amp-hour or ~4% of battery capacity.
Phyrexia502.50 |
06-06-2018, 10:02 PM | #8 |
2124
Rep 2,758
I'd recommend it, but I did bleed someone's system without having a charger available and didn't have an issue. At least do as said above and run in parallel with another battery so you have no worries IMO.
06-06-2018, 10:54 PM | #9 |
Resident Pedant
503
Rep 792
I've had a charger for 10 years and I've used it more than enough times to make it worth the purchase.
I'm sure you CAN do the bleed procedure just fine without one. But it sucks if the battery dies in the middle of any processes like that. |
06-06-2018, 11:13 PM | #10 |
Art Collector
2425
Rep 3,448
Guys guys guys.
I’m all for best practices, but it’s not like he’s flashing his DME where there’s literally zero margin for a dead battery. If OP had a charger, great. But the original question was “should I buy one for this?” The answer is no. It’s overkill. Our cars have big batteries and are able to support moderate current draws on battery alone without issue. For example, the ‘rest’ function activates both a coolant pump and the blower motor, and will run for over ten minutes. Absolutely nothing is going to happen if the car dies midway through, which it won’t if battery is in good shape. There’s nothing magical or uninterruptible about this process. It simply runs the water pump without the engine, that’s it. |
06-07-2018, 04:06 AM | #11 | |
295
Rep 2,202
Should the car's Power Management System detects excessive power loss on the battery it will interrupt the process by turning off the ignition. This doesn't mean the battery is dead though. (Preventable if light switch is set to parking lights).
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
06-07-2018, 06:41 AM | #12 | |
1903
Rep 6,968
06-07-2018, 10:23 AM | #13 |
1006
Rep 2,243
Drives: 2007 328i / 2014 M235i
I give my batteries a full charge 1-2 per year on my smart battery charger, it seems to help maintain their life and puts less strain on my alternator so they do come in handy.
06-07-2018, 10:26 AM | #14 |
718
Rep 1,753
I was actually able to do 2 full cycles of bleeding with no extra charger.. My battery at the time was original too so i think your fine.
06-07-2018, 10:37 AM | #15 |
97
Rep 414
I bled mine 4 times in a row (didn't start the car to allow battery to recharge) after I did the OFHG and coolant flush. No issues at all and my car started right up. I'm on a fresh battery though, fully charged and less than a month old. That's also with the heater at max temp and fan speed at minimum, all lights off.
06-07-2018, 11:33 AM | #16 |
521
Rep 1,485
if you daily drive your car...battery should be strong to go through the bleeding process long as its a healthy battery.
worst case...you would have to take out and get it charged for free at autozone or o reily's. obviously have your rear seats down in case battery dies and you cant open your trunk. |
06-07-2018, 06:22 PM | #17 |
Crazy Frog
543
Rep 1,211
Thanks your all your responses!
