06-06-2018, 01:40 PM | #1 |
183
Rep 229
Clutch pedal redesign or wrong part
I have an 18 LCI, picked up in Nov 2017 via ED. The clutch pedal had a slight click when engaging, towards the top of the arm, as if plastic was hitting plastic about 1 inch into pressing the pedal.
Today, the dealership replaced the clutch pedal (35-31-6-761-310) as well as bushings (35-31-6-797-357), and compression (35-00-6-769-442). The tech said the two pedals looked different around the top of the arm/assembly and the tolerances on the new pedal were much tighter. Therefore, either BMW put the wrong pedal in from the factory (say from a 1 or 2 series that may have different specs?) or they did a recent update to the part. If you also have a click sound coming from the assembly area (reach hand up and you'll feel a spring, so around there) you may have the wrong pedal or it needs to be 'refreshed' by the new part. And yes, this is worthless without a picture, so very sorry.
18 M2 lbb manual exec (Euro Delivery) and PDC
11 e92 335i xdrive BSM/PE (Sold) 09 335i xdrive Monaco Blue (Traded) 02 330xi (Sold) |
06-06-2018, 03:40 PM | #2 |
846
Rep 1,962
Good News: That part number is used on all of the following...
35316761310 CLUTCH PEDAL From:05/31/2004 Part 35316761310 was found on the following vehicles: 1' E81 (02/2006 — 12/2011) 1' E87 (02/2003 — 02/2007) 1' E87 LCI (01/2006 — 06/2011) 1' E88 (11/2006 — 10/2013) 1' E82 (11/2006 — 10/2013) 1' F20 (07/2010 — 02/2015) 1' F20 LCI (05/2014 — 02/2018) 1' F21 (07/2010 — 02/2015) 1' F21 LCI (05/2014 — 02/2018) 2' F22 (10/2012 — 06/2017) 2' F22 LCI (09/2016 — 02/2018) 2' F87 M2 (11/2014 — 06/2017) 2' F87 M2 LCI (09/2016 — 02/2018) 2' F23 (03/2014 — 06/2017) 2' F23 LCI (09/2016 — 02/2018) 3' E90 (02/2004 — 09/2008) 3' E90 LCI (07/2007 — 02/2012) 3' E91 (02/2004 — 08/2008) 3' E91 LCI (07/2007 — 05/2012) 3' E92 (05/2005 — 02/2010) 3' E92 LCI (11/2008 — 06/2013) 3' E93 (09/2005 — 02/2010) 3' E93 LCI (11/2008 — 10/2013) 3' F30 (03/2011 — 01/2016) 3' F30 LCI (09/2014 — 03/2018) 3' F80 M3 (04/2012 — 06/2015) 3' F80 M3 LCI (01/2015 — 02/2018) 3' F31 (07/2011 — 07/2015) 3' F31 LCI (09/2014 — 02/2018) 3' F34 GT (07/2012 — 06/2016) 3' F34 GT LCI (09/2015 — 02/2018) 3' F35 (06/2011 — 08/2015) 3' F35 LCI (01/2015 — 08/2016) 4' F32 (11/2012 — 02/2017) 4' F32 LCI (05/2016 — 02/2018) 4' F82 M4 (02/2013 — 02/2017) 4' F82 M4 LCI (05/2016 — 02/2018) 4' F33 (03/2013 — 02/2017) 4' F33 LCI (05/2016 — 02/2018) 4' F83 M4 (06/2013 — 02/2017) 4' F83 M4 LCI (05/2016 — 02/2018) 4' F36 Gran Coupé (07/2013 — 03/2017) 4' F36 Gran Coupé LCI (05/2016 — 02/2018) X1 E84 (09/2008 — 12/2015) |
06-08-2018, 04:36 AM | #3 |
508
Rep 929
Referencing the above application chart it seems unlikely that the possibility of a wrong clutch pedal being installed would ever happen. Maybe the car was built on April 1st and a clutch pedal from a 2002 was installed as a joke, if anything you may have had a defective pedal installed, but again i can't imagine where the flaw would be. Never had a problem with mine, but did install the UCP only because it seemed like a nice upgrade.
06-08-2018, 07:49 AM | #4 | |
183
Rep 229
04-04-2019, 01:52 PM | #5 |
98
Rep 144
Well, I started having the "click" issue on my 18 recently, it is rather intermittent, I would say around 5% of the time at best. This only happens on the down stroke at the very top of the engagement but the clutch does not feel wrong mechanically. It feels like a "click" as if the spring twisted ever so slightly from the anchor during compression/decompression. I felt the spring from underneath and it does have some lateral movement but that is to be expected, and the c-clip felt like it is in place.
Service advisor asked to have it in so that the tech could take a listen, the problem is that this "click" cannot be reproduced at will, and I almost feel like it is a waste of time at the moment. Guess I will wait for it to get worse. |
04-04-2019, 03:41 PM | #6 | |
183
Rep 229
Can you replicate the click if you press down off center, even slightly either to left or right? For me it seemed to always happen if you didn't press down with perfect center pressure
04-04-2019, 04:00 PM | #7 | |
95
Rep 134
04-04-2019, 04:11 PM | #8 |
98
Rep 144
That was one of the first things I tried to discern if that may be the case, but unfortunately, off-center depression did not always produce the "click". Thanks.
04-04-2019, 04:14 PM | #9 | |
98
Rep 144
04-04-2019, 04:48 PM | #10 |
2432
Rep 2,526
Have the same issue on my 18. Thought it might be the MP pedals.. It never bothered me enough to take it in.
08-03-2019, 09:44 AM | #11 | |
Rep 6
I realize this is an older thread, and it's on the M2 forum, but I am experiencing a similar problem on my 2109 F32. I would like to share and see if anyone else is/has had the same issue and what was the resolution. The car is a 440i Coupe, manual transmission, M Performance Power and Sound Kit. Build was in November 2018. I took delivery in Jan 2019; the car has 5200 miles. In the past month I have noticed a click when depressing the clutch pedal at the very top of its travel. The click can be both felt and heard. Clutch function seems unaffected. I have had the car to my dealer where they found play at the connection of the clutch master cylinder to clutch pedal. They have ordered a new clutch pedal and bushing. As of now, I am waiting for the dealer to advise of part availability and schedule for the r&r. When done, I will update the thread with results. |
skiparock182.50 |
08-03-2019, 03:01 PM | #12 |
1404
Rep 1,466
I too have this intermittently... I have mods and try to reverse them when I go to a dealer, which is a total pain, so haven't had it looked at. I might ask at the next (2 year) service.
2018 ///M2 LCI, LBB, 6MT...
Current Performance Mods: CSF FMIC, ER CP, Fabspeed Cat, Aquamist WMI, GFB DV+, NGK 97506, BM3 (Stage 2 93 OTS), CDV delete, UCP, M2C/M3/M4 Strut Brace, M3/M4 Reinforcement Rings |
08-15-2019, 09:24 AM | #13 |
Rep 6
Update to my post of 03 Aug.
Clutch pedal was replaced on my 2019 440i coupe at 5600 miles. Actual part numbers installed: 35-31-6-761-310 clutch pedal 35-31-6-797-357 bushing, 2 ea 35-31-6-854-283 pin, master cylinder, 1 ea Interesting - and of concern - the part numbers installed by my dealer seem to have been replaced by newer part numbers according to realoem.com. The replaced by part numbers are: 35-00-6-878-300 clutch pedal 35-00-6-878-303 bushing, 2 ea 35-00-6-878-304 pin, master cylinder 1 ea The new clutch pedal now works as expected with no clicking noise or feel at the top of its travel. My hope is it will remain this way as it wears in. Side note: my dealer's mechanic scratched the hell out of the stainless steel dead pedal while doing the clutch pedal replacement. Not a big deal at the end of the day, but neither is it the kind of workmanship I am willing to accept. Back to the dealer! |
