06-05-2018, 08:55 PM | #1 |
Rep 18
Dash cam
Hi, I’m looking to install a dash cam on my F36 but wanted to know which is a good one based on my requirements. Basically I want a tiny discreet camera that is hidden behind the rear-view mirror. As I want a tiny one, I would obviously not need one with a screen on it - instead I would prefer it to have wifi so that I can view recordings on my smartphone. I have seen small ones that fit my requirements on ebay but not sure how good they are and how discreet they would be in my F36. Would appreciate some recommendations guys.
06-05-2018, 09:47 PM | #2 | |
279
Rep 689
06-05-2018, 10:25 PM | #3 | |
4488
Rep 10,473
Look no further. http://f80.bimmerpost.com/forums/sho....php?t=1501978 |
06-05-2018, 10:30 PM | #5 | |
279
Rep 689
06-06-2018, 04:40 AM | #6 |
Rep 18
Jesus, didnt realise how expensive it is. Plus I’m not sure where I can hide that behind the mirror as its pretty wide.
Any other recommendations that are below $100? |
06-06-2018, 05:24 AM | #7 |
35
Rep 41
Pen and paper might give you the results you are after at that price. The write speed of the memory card might be a bit slow though.
Poon Stick42.50 |
06-06-2018, 07:15 AM | #8 |
4516
Rep 8,942
This is the most stealth option but must be hardwired to battery.
http://www.incarbite.com/en/productD...d=VD_Camera_OE Cheapest /easiest with decent quality check Goluk. I have that one and chose over Blackvue because it's USB powered so I could easily plug it into the port in my glovebox.
2022 Macan S
2016 F31 328i xDrive Sport Wagon 2006 E46 330ci ZHP Convertible |
06-06-2018, 08:57 AM | #9 | |
68
Rep 117
It's not even about video quality, it's about the quality of the device itself. I used to have a cheap (something around $120, I guess) Qstar dashcam, and after a couple of months it began to overheat and hang within an hour of constant recording. It was repaired and reflashed several times during the year of warranty, but this caused no difference, then warranty ended and it just died half a year later. IMO, reliability is the main factor for the dashcam, as you need to be sure it is recording all the time you're driving. I doubt any cheap device will be dependable enough. Blackvue is generally considered as a top-end brand, they are pretty reliable, have decent video quality and support. I use $200 Trendvision dashcam, it's good enough for its price, but this is a local company, so, unfortunately, they are not available outside Russia. |
06-06-2018, 10:04 AM | #10 |
445
Rep 752
Anyone who says you can't get a quality dashcam for ~$100 doesn't know what they're talking about. Dashcamtalk has extensive reviews and takedowns of dashcams at that price-point, and the Viofo A119S routinely comes up as a decent entry-level option.
GPS quick-detach mount, excellent night time clarity, supercapacitor so overheating/battery failure doesn't happen, etc. Extremely plug-and-play. https://dashcamtalk.com/viofo-a119s/ https://www.amazon.com/gp/product/B0...&tag=dacata-20
BEM-S44515.50 |
06-06-2018, 04:43 PM | #11 | |
Rep 18
06-06-2018, 04:47 PM | #12 | ||
4516
Rep 8,942
2022 Macan S
06-06-2018, 05:39 PM | #13 |
Rep 18
Could I hardwire it though so I can keep my 12v port free? Also I see no mention of it fitting a F36. If I’m correct, its the same layout behind the mirror as a F30?
06-06-2018, 06:01 PM | #14 |
IG @F30_MPE
257
Rep 703
Below $100 won't get you WiFi, but I would recommend the Thinkware F50. Full 1080P recording with parking mode/hardwiring capabilities for about $100.
2018 F30 340i | M Performance Edition Alpine White | Individual Black Merino Leather |
06-06-2018, 06:45 PM | #15 |
Masterchief
362
Rep 1,015
ROAV C1 Dashcam by Anker.
has the wifi and capability to stream videos over their app on your phone. Paid 100$ on amazon. iv had for a year and no issues whatsoever
AWE Non-Res Touring | TE37 SL PW | Ohlins RT |
06-07-2018, 10:03 AM | #16 |
5886
Rep 10,256
I also decided to purchase BlackVue DR750S-2CH with a dedicated Cellink NEO battery after after extensive research. Generally, it performs well. The firmware support from BlackVue could be better and I always stay at N-1 firmware release level.
https://dashcamtalk.com/forum/ is an invaluable resource. |
06-07-2018, 10:12 AM | #17 | |
130
Rep 606
bad karma445.00 |
06-07-2018, 10:15 AM | #18 |
4516
Rep 8,942
Amazon has an OBD Blackvue cable for $20 that promises easy install and battery minding. I haven't tried it but might be worth looking into.
2022 Macan S
06-07-2018, 05:34 PM | #19 |
1455
Rep 1,487
Drives: 2108 X3 xDrive30i
I'd recommend any of the Blackview cams...very discrete. Owl dash cams, I hear are starting to take a piece of the market though.
06-11-2018, 08:59 AM | #20 |
Rep 20
If you want proper budget and no screen, the BlueSkySea B1W might fit the bill. I've got mine installed underneath the rear view mirror in a way that I can't see it while driving and all the cabling runs under the plastic housing to the headliner and down to the under-glove box 12v socket. Has an app for accessing via wifi and gets very good reviews, cost me £50 off Amazon plus a tenner for the 32gb card.
