Boost leak related to O2 sensor issue?
06-05-2018, 08:18 PM | #1 |
41
Rep 117
Hello I'm getting P2195, P2414 and P0171 codes which are related to a O2 sensor, in this case its running lean. Bank 1 sensor 1 seems to be the problem. I have a small boost leak where the outlet connects to the intercooler. The O-ring is bad and connection becomes loose. Could it be running lean due to the boost leak? The O-ring is on the way. The reason I'm asking is because I got the check engine light due to these codes after the boost leak. Thanks.
06-05-2018, 10:26 PM | #2 |
1209
Rep 2,476
Not likely, since intake air and MAP are measured after the leak. Fix the boost leak, since that's a known, no reason not to. Then see if O2 sensor and codes come up. Not good to run lean, one of the biggest engine killers.
